Question about Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion
Dremel 10.8V cordless model 800 (8000) The speed is stuck on the high setting (variable doesn't work now) and battery lights no longer work. I'm assuming its the switch and now needs expensive repair. Only used once every three to four months.
    Sergeant:
    Novelist:
  • 157 Answers
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Posted on Nov 06, 2010
New Dremel 7700 not working on higher speed
I'm having the same issue. Can't find any more nformation to fix it
Jun 21, 2013 | Dremel 7700-1/15 7.2V Cordless Two-Speed...
Variable Speed Control is faulty
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
Apr 16, 2009 | Dremel Variable - Speed Multipro Rotary...
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Mar 02, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
Jan 09, 2009 | Dremel Variable - Speed Multipro Rotary...
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
I need a coupling
Call Dremel at 1-800-275-2052 and they can help with parts and schematicsHope this helps. Dave
Nov 08, 2008 | Dremel Variable - Speed Multipro Rotary...
New dremel
It was just retired there is nothing recalled its just an old model
Oct 17, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Scroll Station 1800
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
Feb 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion Logo
902 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
