Question about Maytag Washing Machines
I have a model # Lat2600aae maytag and when washing the auger floats up and not moving clothes wut can i do to fix the problem?
SOURCE: MAYTAG LEGACY MODEL # SAV205DAWW
I've got the same problem. The diagram is a bit deceiving because it appears to show the agitator/auger as one piece. However, the bolt only holds the agitator (lower portion) and then the auger slips in place over that. The fabric softener cup then snaps to the top of the auger.
Best I can tell is that the slotted 'ears' on top of the agitator are worn thus preventing a secure fit between the agitator and auger. I just finished putting some hard thumb pressure on each of the ears and bent them outward some. The auger fits much tighter now and I'm doing a test run of clothes. It is holding but I will probably have to replace what they describe as the agitator / auger assembly, costs $53.54. I don't see any other fix but would appreciate further input.
Thanks
Posted on Apr 09, 2008
  • 30 Answers
SOURCE: maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Posted on Jun 02, 2009
  • 245 Answers
SOURCE: My Maytag washing machine leaves residue (lint? soap?) on clothes
us liqwid soap us les chang filter.to meny close can trap the dry stuf.
Posted on Jan 25, 2010
SOURCE: Maytag washing machine, model LAT2600AAE, stopped
On the underside of the machine, you'll see the belts from the motor to both the drum and the water pump. If the belt to the pump is intact, check to see if it is loose. If so, you'll see 3 screws holding the pump housing in place. Try to readjust the pump so the belt is a little more snug. This worked for mine that was having the same problem. You may need to remove the front panel to reach the drain hose to drain your drum 1st - have a couple buckets and towels handy as well as someone else to run and dump your full buckets. Good luck.
Posted on Jul 31, 2010
  • 121 Answers
SOURCE: I HAVE A MAYTAG LAT2600AAE WASHER 8 YRS OLD. IT
The tub seal is leaking this page should help http://appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
Maytag washing machine, model LAT2600AAE, stopped draining water in spin cycle. The motor agitates cycle but will not drain water. What can I do? I'm not a pro at fixing these things.
Mar 30, 2010 | Maytag Washing Machines
The agitator is no longer attached
There is a small set screw located lower on the agitator. Locate the set screw and tighten. This should solve the problem.
Jan 05, 2010 | Maytag Washing Machines
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Maytag washer noise during wash cycle
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
Disassembly of washer agitator
With the palm of your hand, bang the very top section of the agitator, there are no screws, it is just a firm push-fit.
Do it with the agitator locked in the tub.
Oct 14, 2017 | Maytag Washing Machines
I have a Maytag performer series machine,the main agitator is screwed down properly but the corkscrew agitatorthat is attachedto the main agitator completely cuts loose and floats to the top , i don"t...
With the Maytag Performa series, the auger is held by a pressure fit only - no screws. Mine failed after about 6 years. There is no (easy) way to repair this problem. The top auger does not stay attached to the post, and it floats off the post while washing... I ended up ordering a new one from the Sears 1-800 number. Easy to replace, and it comes with both the post and auger. Costs about $110, but certainly a lot cheaper than buying a new machine. The part does not come with the top cap for fabric softener, so be sure to save the old one. You do need a fairly long extension for your ratchet wrench to unscrew the attached bolt, but it is fairly easy to do.
May 30, 2008 | Maytag Washing Machines
Thanks
Feb 01, 2008 | Maytag Legacy Series Top Load Washer
Maytag SAV365ZAWW Agitator Comes Apart
The should be a bolt that goes thu the center that holds that down with the bottom part of the agiatator.. it might have pulled loose or rounded out the whole for the top part here is a link and a pic http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365ZAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20INNER%20%26%20OUTER%20%28SERIES%2012%29&titleID=00010&
Sep 19, 2007 | Maytag SAV365Z Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
