Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Lawn edger stops working after 2 uses
The machine just stopped working in the middle of the 2nd job. A deaf friend was using it, but I was right there and did not hear any seizing etc. It's like there is no electricity going to the machine even though there is. The Home Depot guy told me that they may have a fuse. Is this true?
  • christine111 Jun 17, 2008
    Well I was wondering if the Black and Decker Edger (This place would not let me post under the actual correct equipement name as it is NOT what is shown at the top of the post but strictly the "lawn Edger" only). Anyway, I was wondering if this piece of equipment has a breaker box" I haven't taken it apart to look yet but I was wondering about fuses with the way it just shut off, dead. Thanks Christine
Did you check your breaker box? Mine sometimes blows the house fuse if I hit a big rock or something. I've never had any problems with internal fuses and I've owned mine for 3 or 4 years. Also, you may have to check the armature (the part that spins inside.) I had the same problem with my dremel tool. It's all magnetic and if the electrical current gets disrupted, the armature won't spin.
Posted on Jun 15, 2008
My Flymo Contour 700 stopped working when in use how do I get it to work again
check its safe to keep using
an electrician or flymo service center to check it all over
Sep 11, 2016 | Garden
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Aug 13, 2016 | Ryobi Garden
My cord worx hedge trimmer, which has had very minimal use, stopped after trimming rosemary hedge. Any use trying to repair?
Worx is not a premium brand and repair shops cost a lot so if you aren't able to check the cables and machine yourself or have a friend or neighbour who can do so cheaply it will probably be more satisfactory and possibly cheaper to replace which would be a great pity as the chances are the fault will be small and discarding stuff which isn't worn out (consumerism) is part of what is destroying our planet.
Owning and using appliances is something for people who can look after them and maintain them or for people with more money than sense.
My advice is to surround yourself with a circle of friends willing to do what you can't or help save the world by learning how to trouble-shoot and repair stuff yourself.
Apr 19, 2015 | Worx Garden
What do we use to keep the worx trimmer/edger clean?
Sally once you finish using it give it a soft brush over then use some WD40 on a rag and lightly go over it. This should stop any grass sticking to it and keep it nice and clean.
Oct 26, 2014 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Worx WG112 trimmer line breaks
Sounds like line is on backwards, wrong diamiter line or worn parts.
Joe Don
May 25, 2012 | Worx Garden
Im trying to figure out how to install the safety guard.Can you help me?
On this page you will find a tab for the owners manual. The regular site I use has no Worx machines listed at all. I hope this helps you. The tab for MANUAL is near the middle right of this page. Hope the assembly info you need is there.
http://www.worxyardtools.com/cordless/grass-trimmers.html
Aug 14, 2010 | Worx GT WG150-2 18 Volt 10 in. Cordless...
Why would it stop recording in the middle of a
1st question. What stops recording? Or do you mean the turntable stops playing in the middle of the LP?
2nd question. The weight to set depends on the cartridge fitted. If the cartridge says 4 grams for it set at that. The trick is to set it so that it keeps in the groove of the record and not jumping, except on bad records of course. If you pick up a lot of rumble (during the gaps for instance) it will have too much weight on. On the back of the arm should be a ring or something with numbers on. Turn it till a number matches the indicator mark. The number you chose should match the weight required.
They used to sell a gauge for stylus pressure. Don't know if you can still get them.
Jan 02, 2010 | Audio Players & Recorders
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
142 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
