Convergance I put in the new STK392-040 in my Samsung projection tv. It had STK392-010 in it, and now the green out of sink no blue and it heated up piece up on the board. What are your thoughts?
  • 8,617 Answers
You most likely have some resistors that are needing to be replaced its not uncommon for Samsungs ICs to open a couple resistors when the ICs go out and installing new ICs with the old ones being open can cause more of the convergence resistors to burn. Post the model number of you set and I can let you know which resistors you likely need to replace.
Posted on Jun 14, 2008
Convergence problem
The convergence board is bad in this set. Samsung no longer has this board in stock. You will have to take the board out and rebuild it by replacing both of the STK convergence amp IC's These IC's are soldered to the printed circuit board. They will be standing up against a metal plate, called a heat sink. They are black in color and are about 2" by 3" . They have white lettering on them that start with STK and the some numbers. You get those numbers and go to mcmelectronics.com, enter the exact number of the IC and order two of them. Before you install the new IC's you will need to apply some heat sink compound onm the back of the new IC's. This heat sink compound is avaialable thruogh radio shack. Good Luck
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
STK392-010
There are usually two one contains three amplifiers so there are two for the Red two for the Green and two for the Blue.
Mar 28, 2009 | Samsung HC-P4752W 47" Rear Projection...
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Dec 25, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HC-P4752W 47 in. Rear Projection bigscreen TV
You dont have to remove the aluminum heat sink. The ICs are attached with screws and then just unsolder the ICs from the circuit board and then replace the new ics into the pin hole locations after applying heat sink compound onto the back then screww the new ICs to the heat sinks then solder the pins. Very easy repair.
Jun 19, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | Samsung HCM5525W 55" Rear Projection...
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
Sony Convergence
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
I have a big screen with three lines at bottom of screen
Likely to be the convergence power supply module. If you fix yourself it is simple provided you can get the module. Take the back off AFTER unplugging set The module is located above the main board on the left and the dynamic convergence board on the right. and come out by about 4 quarter inch nutdriver screws and has only two plugs one on each end of the module. You may find a good used one at your local tv shop or get them to order a new one or fix the existing module by changing the chip on it where the metal heat sink is. Chip number is STK 730-010 or STK 730-130. Either will work. Chip will usually fix it. If not the entire module must be replaced
Jan 01, 2008 | Proscan PS50670 50" Rear Projection...
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
