Question about JVC AV-27D501 TV
I have a JVC AV-27D501 TV, I'm trying to connect a DVD player to the TV but not able to get the Video or Audio. My DVD player has Video Out (Yellow) and Audio out (white & red). Connected the AV cables to the front panel of TV and changed the INPUT on TV to Video 1, Video 2 and Video 3, but no luck. On selecting Video 3 I could hear some sound just for a moment (comes & goes). I even tried all the jacks on the back side but nothing worked. Pls suggest a solution
  • JVC Master
  • 11,800 Answers
I'm assuming the cable was plugged correctly - the colors matched. VIDEO 3 is for the front connectors so it should have worked . Since it hasn't then one of the three parts in this setup (tv, player, cable) is defective. To find out which you must do some simple tests:
1. replace the cable and try again.
2. take your player and connect it to a surely functional tv - if it doesn't work in there then it's defective.
3. get another player that is surely functional and connect it to your tv - if it doesn't work then the AV switching IC from your tv (soldered on the mainboard) is defective and it will have to be replaced. Call a repairman, there is nothing more you can do.
Posted on Nov 06, 2010
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
I cannot figure out which RCA jack output do you plug the jacks into to hook up a dvd player?
AV input wire will have three connections. Red, Yellow andWhite. Out of which, Yellow one should be connected to Video Out of the DVD player, and the other two, Read and White; to be connected to the audio out left, and audio out right of the DVD player. The other ends of this wire should be connected to Video In, and Audio In socmets of the TV. Keep trace with the colour of the socket and connect it. Select the Input of the tV to AV. Switch On both the devices. If the connection is correct, you will see the logo of the DVD player on the tv screen.
Mar 19, 2012 | iLO IWT3206 TV
Can't get my Proview TV to recognize the signal
Good day!
Please check the connection of the jack from your TV to DVD.
Follow this step on how to connect the AV (audio and video) jack.
  • For the DVD connection.
  1. Find out where is the video out of the DVD.It is usually have a label (video out) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video out of the DVD.
  3. Next,find out where is the audio left and right out of the DVD.It is commonly have a label (rear,front and center) choose 1 of the location you want.also it have a standard color (red and white)
  4. After that,connect the AV jack(red and white)to the audio out of the DVD.
  • For the TV connection.
  1. Find out where is the video IN on the rear side of the TV.It is usually have a label (video in) and the color is yellow.
  2. After that,connect the jack (color yellow) to the video IN of the TV.
  3. Next,find out where is the audio left and right IN of the TV.It is commonly have a label (audio in ) and found in the rear side of the TV.also it have a standard color (red and white).
After you connect the AV (audio/video) jack.Try to open the TV and the DVD and set your TV to the AV mode by pressing the AV label on the remote or on the TV button.
If the video is not appear on the AV1 try AV2 ,AV3 and so on.Or also try other AV on the TV.
I hope this solution will be helpful.Thank you and good luck.
May 06, 2011 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
The video of my jvc dvd player won't display on my tv screen or the video is not working but the audio is ok.
Connect the yellow connector on the DVD player to the yellow connector on the TV. Refer to the TV manual and select the video input. Refer to DVD manual and choose interlace on the DVD player. Let me know if this helps
Jan 13, 2010 | JVC XV-N322 DVD Player
Connecting DVD player to Viewsonic TV
You will use component video cables.  They come in threes and all they require you to do is connect the DVD output with the TV input and match the cable colors on both ends.  They will be red, white, and yellow.  The yellow is the video, and red and white are left and right audio.  If your TV is too old to have stereo audio, only one (red or white) audio cable needs to be connected.  It doesn't matter which.  The yellow cable always needs to be connected.
Another option, but a slightly less common one, is to use a single AV cable to connect the two.  The reason this is less common is because most newer TV's do not have AV input, and newer DVD players do not have AV output.  If it does, however, this is the most simple, and you probably wish to take advantage of it, so you have a connection available when you purchase a newer unit which does not have AV.
Aug 13, 2008 | JVC XV-N212 DVD Player
Can't find my user manual and need help hooking it up
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
Jul 30, 2007 | Curtis CMD5000 DVD Player
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
JVC AV-27D501 TV Logo
69 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
