When you put the top down you have to push down hard on the right side where that plastic pin is that makes it turn on. do i have to replace the pin and washer.
  • 4,070 Answers
The pin pushes on the lid safety switch. It may be bent out of position. Lift the top panel up to access the switch to see why the pin isn't reaching it.
Posted on Nov 06, 2010
The horn in my 1999 Pontiac Grand Am GT dues not wrok how do i fix it and get to it thank you Michelle
check the relay and fuse first. it is in underhood fuse box on drivers side. the fuse is # 43 and its a mini fuse. the relay is # 21 and its a micro relay. to access horn remove right front headlight housing. on top of headlight housing there are 2 plastic slide pins. just pull them up to release housing. then look down to horn. when putting housing back on just push in on housing and push pins back down. have a good one !!
Feb 25, 2011 | Pontiac Grand Am Cars & Trucks
I'm trying to install Artic Cooling 7 Pro, however I cannot get the large type push pins in the screw sockets. I can see on youtube that other people have small push pins. I've ended up putting the...
The push pins get rotated a 1/4 turn to lock or unlock them. Make sure it is unlocked and then pull up on the black plastic push pin. This will make sure it is unlocked. Repeat for the remaining 3 push pins. If you look at the bottom the little clear/white plastic pieces at the bottom should not have a black piece of plastic piece pushed down and showing all the way. You can then take the cooler and line up all the holes with the pushpins but dont push down on them yet. Push down on the top of the cooler to put the white plastic pieces through the holes. Then rotate the black top push pins to the locked position and push down on the locking push pin.
Feb 15, 2011 | Arctic Cooling Freezer 7 Pro
How do you replace the platenroller guide rollers?
to replace the feed rollers under the platen. 1 - remove the platen by squeezing the black plastic clips at the ends of the platen and pulling the platen straight up. 2 - pull the paper pan out, 3 - push down on the feed roller set and rotate it towards you. replace bad rollers and put things back in reverse order. there is a guide on the rod the feed roller unit sits on, make sure the guide on the feed roller unit goes back in this. there are pins at the right side and left side of the right and left feed roller units. these are for positioning the paper pan in the slotted tabs on the bottom of the paper pan. make sure the gear on the platen goes on the left side, position the clips to center on the frame, then push straight down. make sure both clip are fastened in. the only reason you should be replacing these rollers is if they are splitting apart or falling off due to the pins at the ends of the rollers wearing off (never seen this happen on a WW6) if you are having some sort of other problem, you might ask for a different solution before doing this - its harder than it sounds.
Dec 20, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
Cuisinart grind and brew pot - door holding filter pops open during grinding/brewing.
There is a little cover over a spring. The loops of the spring go inside the screw that holds the cover. The spring ends are against the wall and a small pin connected to the button on the side. Keeps the button locked. Cleaning out dried coffee in the are may help and pam spray may keep it from sticking.
Oct 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
How do you replace the headlight assembly on a 99 Pontiac Grand Am?
  1. Open the hood to your Pontiac Grand Am. Have the car keys on you, but not in the ignition and make sure the lights are in the "off" position.
  2. Step 2 Locate the splash guard and the plastic push pins that hold it down. It runs along the entire front frame rail. Removing the entire splash guard will make it easier to to remove even one headlight on one particular side.
  3. Step 3 Remove the pins by lifting up on the center of the pin. Pull it up about 1/4-inch and then pry the pin insert and pin out of the hole.
  4. Step 4 Locate and remove the two-headlight assembly bolts on the the top of the headlight assembly. Use the ratchet and a socket to remove the bolts.
  5. Step 5 Pull the headlight assembly forward by hand. Be careful not to scratch the lens of the assembly or scratch the paint on the front bumper.
  6. Step 6 Unplug the wire from the back of the headlight that is blown out.
  7. Step 7 Turn the headlight bezel counterclockwise (about 1/4 turn) until it releases the headlight from the back of the headlight assembly. Extract the old headlight and discard it.
  8. Step 8 Insert the new headlight into the headlight assembly. Be careful not to touch the glass of the bulb. Handle it only from the bottom.
  9. Step 9 Replace the bezel and turn 1/4 turn clockwise until it locks into place.
  10. Step 10 Plug the wire back into the headlight and rest the assembly onto the bumper gently so you can turn on the lights to test and make sure the headlight it working properly.
  11. Step 11 Insert the headlight assembly back into place. Replace and tighten the headlight assembly bolts.
  12. Step 12 Put the splash guard into place and place the push pins into position. Insert the pin and its insert into the hole with the pin still in the "up" position. When the insert is seated flush to the splash guard in the hole, simply push the pin down to lock.
Jan 30, 2010 | Pontiac Grand Am Cars & Trucks
Changing headlight, low beam, drivers side, 2002 Malibu
underhood at light there are two plastic slide pins on top of assembly. pull up on the pins to release assembly. then pull assembly from car, now you can replace the bulb. when putting back on, push in on assembly and push the pins down to hold it in.
Jan 08, 2010 | 2003 Chevrolet Malibu
I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
  • Press the "Power" button to turn on your Lexmark
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
  • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Nov 19, 2009 | Office Equipment & Supplies
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
Where do you insert the ink cartridges on lexmark x4650
These are the instructions for X2500 Printer
1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
2.Open the top portion of the printer to reveal the ink cartridges.
3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
Oct 25, 2009 | Lexmark X2500 All-In-One Printer
Washing Machines Logo
Top Washing Machines Experts
