Question about Home
How to install jetmatic water pump - Home
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
Water pump
Which engine?
  1. Drain the radiator
91192665
  1. Loosen the water pump pulley bolts.
  2. Remove the serpentine belt.
91192666
  1. Remove the water pump pulley bolts and pulley.
  2. Remove the water pump bolts, pump and gasket.
  3. Clean the water pump mating surfaces.
  1. Install the water pump gasket and pump.
91192667
  1. Install the water pump bolts. Tighten the water pump bolts to 89 inch lbs.
91192668
  • Install the water pump pulley and bolt until snug.
  • Install the serpentine belt.
  • Tighten the water pump pulley bolts. Tighten the water pump pulley bolts to 18 ft. lbs.
  • Fill the cooling system and purge of air.
  • Inspect for leaks.
  • Sep 27, 2012 | 2001 Oldsmobile Alero
    Change the water pump
    • Tools Required
    • J 43651 Water Pump Holding Tool
    • Remove the thermostat housing.
    • Remove the water pump access plate from the front cover.
    • Remove the right hand fender liner.
      1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
      Drain the coolant from the water pump using the plug at the bottom of the pump.
      1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
      Install the J 43651 into position.
      1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
      2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
      3. Remove the 3 inner water pump sprocket to water pump blots.
        1. Important: Be sure to remove both water pump bolts from the front of the engine block.
        Remove the 2 water pump bolts.
        Remove the rear 2 water pump bolts.
        1. Remove the water pump.
        2. Remove and discard the water pump O-ring seal.
        1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
        Install a NEW water pump O-ring seal.
        1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
        Using the guide pin, align the pin with the water pump holding tool.
        1. Position the water pump against the engine block and hand tighten the water pump bolts.
        2. Notice: Refer to Fastener Notice.
        Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
        Tighten the bolts to 25 Nm (18 ft. lbs.).
        1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
        2. Remove the J 43651.
        3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
        4. Install the right hand fender liner.
        5. Install the thermostat housing.
    Aug 29, 2011 | 2006 Pontiac Solstice
    How long does it take to replace a water pump on Pontiac Aztec?
    It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
    Removal Procedure :
    1. Drain the cooling system until the coolant is below the level of the water pump.
    2. Remove the drive belt guard.
    3. Loosen the water pump pulley bolts.
    4. Remove the drive belt.
    1. Remove the water pump pulley bolts.
    2. Remove the water pump pulley.
    1. Remove the water pump bolts.
    2. Remove the water pump.
    3. Remove the water pump gasket.
    4. Clean the water pump mating surfaces
    1. Install the water pump gasket.
    2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
    3. Install the water pump bolts.
    1. Install the water pump pulley. Loosely install the mounting bolts.
    2. Install the drive belt.
      • Tighten the bolts to 25 Nm (18 inch lbs.) .
    1. Install the drive belt guard.
    2. Fill the cooling system.
    3. Inspect the cooling system for leaks.
    4. That's it.
    Nov 18, 2010 | 2001 Pontiac Aztek
    How to replace water pump 2003 alero. 3400 engine.
    Removal & Installation 2.2L Engine To Remove:
    1. Disconnect the battery ground cable.
    2. If equipped with an automatic transmission, remove the exhaust manifold..
    3. Drain the cooling system.
    4. Raise and safely support the vehicle.
    5. Remove or disconnect the following:
      • Right front wheel and tire assembly.
      • Access plate on the water pump sprocket from the timing cover.
    6. Install J 43651 water pump sprocket holder or equivalent to the water pump sprocket.
    7. Use the access plate bolts to attach J43651 to the engine front cover.
    8. Remove or disconnect the following:
      • Bolts that secure the sprocket to the water pump.
      • Bolt that secures the engine block to the water pump.
      • Bolt that secures the engine front cover to the water pump.
      • Feed pipe that joins the thermostat housing to the water pump. chevy_cav_02-04_wp.gif
      • 2 Bolts that secure the water pump to the engine block.
      • Water pump.
    To Install:
    1. Use a threaded stud in the hub to align the water pump sprocket.
    2. Install or connect the following:
      • Water pump.
      • 2 bolts that secure the water pump to the engine block.
      • Front cover bolt and the bolt that secures the engine block to the water pump. Tighten the bolts to 15 ft lbs (20 Nm).
      • 2 of the bolts that secure the water pump sprocket to the water pump.
    3. Remove the threaded stud.
    4. Install the last bolt.
      • Tighten the bolts to 89 in lbs (10 Nm).
    5. Remove J 43651.
    6. Install the access plate on the water pump sprocket to the timing cover.
    7. Install the access plate bolts.
      • Tighten the bolts to 18 in lbs (10 Nm).
    8. Install the front fender liner.
    9. Install the right front tire and wheel.
    10. If equipped with an automatic transmission, install the exhaust manifold.
    11. Fill the cooling system.
    12. Connect the battery ground cable.
    2.4L Engine To Remove:
    1. Disconnect the negative battery cable
    2. Drain the engine coolant.
    3. Remove the exhaust manifold.
    4. Remove the coolant intake pipe as follows:
      1. Remove the coolant inlet pipe bolts.
      2. Remove the wheel and tire assembly.
      3. Remove the engine splash shield.
      4. Remove the bolts from the transaxle-to-engine block brace and remove the brace.
      5. Remove the radiator hose from the coolant inlet pipe.
      6. Remove the coolant inlet pipe to oil pan bolt.
      7. Remove the coolant inlet pipe, thermostat and seal.
    5. Lower the vehicle.
    6. Disconnect the heater hose quick connect from the heater outlet pipe.
    7. Remove the front timing chain cover and the chain tensioner.
    8. Unfasten the water pump-to-cylinder block bolts.
    9. Remove the water pump-to-timing chain housing nuts.
    10. Remove the water pump and cover mounting bolts and nuts.
    11. Remove the water pump and cover as an assembly. Separate the two pieces after removal.
    12. Clean the mating surfaces.
    To Install:
    1. Install the water pump cover to the water pump assembly.
    2. Install and hand tighten the pump cover mounting bolts.
    3. Install water pump cover assembly.
    4. Install and hand tighten the cover-to-block mounting bolts.
    5. Install and hand tighten the water pump-to-timing chain housing nuts.
      • Tighten the water pump-to-timing chain housing mounting nuts to 19 ft lb (26 Nm).
      • Tighten the water pump cover-to-water pump mounting bolts to 124 in lb (14 Nm).
      • Tighten the water pump cover-to-engine block bolts starting with the bottom bolt first to 19 ft lb (26 Nm).
    6. Install the heater hose to the water pump pipe.
    7. Using new gaskets, install the exhaust manifold.
    8. Install the oil level indicator and tube.
    9. Connect the brake vacuum tube to the cam housing.
    10. Raise and safely support the vehicle.
    11. Install the catalytic converter.
    12. Install the coolant inlet pipe.
      • Tighten the inlet pipe-to-oil pan bolt to 19 ft lb (26 Nm). Tighten the coolant inlet pipe bolt to 124 in lb (14 Nm).
    13. Install the timing chain and tensioner.
    14. Lower the vehicle.
    15. Connect the oxygen sensor.
    16. Fill cooling system and check the system for leaks.
    3.4L Engine To Remove:
    2. Drain the cooling system.
    4. Remove or disconnect the following:
      • Drive belt.
      • Water pump pulley bolts and pulley.
      • Water pump bolts, pump and gasket.
      • Clean the water pump mating surfaces.
    To Install:
    1. Install or connect the following:
      • Water pump gasket and pump.
      • Water pump bolts.
        1. Tighten the water pump bolts to 89 in lbs (10 Nm).
      • Water pump pulley and bolt until snug.
      • Drive belt.
    2. Tighten the water pump pulley bolts to 18 ft. lbs (25 Nm).
    3. Fill the cooling system.
    4. Check for leaks.
    5. Connect the battery ground cable.
    Aug 31, 2010 | 2003 Oldsmobile Alero
    How to take off the water punp
    1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
    Aug 13, 2010 | 2002 Buick LeSabre
    Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
    Visit my Blog here
    Jul 21, 2010 | 2002 Buick Rendezvous
    How do I change a water pump on a 2004 kia sorento?
    Kia Sorento 2003-05
    Water Pump - Removal & Installation
    1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
    3. Disconnect the negative battery cable.
    4. Remove the drive belt and the water pump pulley.
    5. Remove the timing belt cover, timing belt, auto tensioner and idler pulley.
    6. Remove the water outlet fitting, the thermostat case and the water pump fitting.
    7. Remove the water pump mounting bolts.
      Fig. Water pump and timing belt assembly-exploded view
    To install:
    Fig. Water pump bolt locations
    1. Clean the gasket surfaces of the water pump body and the cylinder block.
    2. Install the new water pump gasket and pump assembly. Tighten the bolts to 12-16 ft. lbs. (17-22 Nm).
    3. Install the water pump fitting, the thermostat case and the water outlet fitting.
    4. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
    5. Install the drive belt, water pump pulley and then adjust the auto tensioner.
    6. Refill the coolant.
    7. Run the engine and check for leaks.
    1. Before servicing the vehicle, refer to the Precautions Section.
    To install:
    Fig. Water pump O-ring installation
    6. To adjust the drive belt tension, hang the belt on the pulley of the tensioner and install the tensioner.
      NOTE If the tensioner is already installed, loosen its mounting bolts to allow belt installation
    7. Install the drive belt.
    8. Adjust the belt tension to specification by turning the adjusting bolt clockwise or counterclockwise.
    9. Air conditioning belt tension should be 0.28-0.039 inch. Alternator belt tension should be 0.39-0.051 inch. Power steering belt tension should be 0.31-0.051 inch.
    10. Torque the tensioner assembly bolt to 33-36 ft. lbs. (45-50 Nm).
    11. Refill the coolant.
    12. Run the engine and check for leaks.
    TY for using Fixya; remember comment and rated this.
    Apr 01, 2010 | 2004 Kia Sorento
    How do you replace a water pump in an aztec?
    Notes Water Pump Replacement
    Removal Procedure
    Jun 17, 2009 | 2001 Pontiac Aztek
    Water pump replace
    Water Pump Replacement (3.8L)
    Removal Procedure
      3. Remove the power steering pump and reposition.
      4. Remove the water pump bolts.
        2. Remove the water pump gasket.
        3. Clean and inspect the water pump mating surfaces.
          1. Notice: Refer to Fastener Notice in Service Precautions. Install the water pump bolts.
            • Tighten the long water pump bolts to 34 Nm (25 ft. lbs.) .
            • Tighten the short water pump bolts to 22 Nm (16 ft. lbs.) .
              2. Install the water pump pulley bolts.
                • Tighten the bolts to 13 Nm (115 inch lbs.) .
              1. Install the power steering pump.
      5. The Whole Thing I Know You Didnt Want to hear that about The P/S Pump Thats why I Did More Reserch you seemed to Know what You are Doin They get the Best of us though Hope this Helps & RATE ME PLEASE
    Feb 03, 2009 | 2005 Chevrolet Impala
    Home Logo
    626 people viewed this question
    Top Home Experts
    john h
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
