Question about Weber Genesis Silver B Grill
Weber gas grill parts
Where can I purchase a Used " lid assembly" part # 60542 for a Weber Genesis 1000 series
SOURCE: Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Posted on Jul 18, 2008
  • 63 Answers
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Posted on Mar 14, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
SOURCE: Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Posted on Apr 30, 2010
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
Posted on Jun 13, 2010
Assembly manual weber 310
i am having trouble lining the body of Weber Genesis 310 to the holes on cart sides. they seem to be off 3/8" towards front of grill. Could their spec be off or assembled incorrectly. I have gone over instructions several times & can't see where I went wrong.
Dec 23, 2011 | Weber Genesis E-310 Gas Grill
What model rotisserie will fit a Weber Silver B 250000 model gas grill
You need the Genesis E/S-series rotisserie. It is part # 7519 and can be located at the page below:
Genesis E/S series Rotisserie
Sep 14, 2011 | Weber Genesis Silver B Grill
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
Bought a weber genesis 320 Problem with the Weber Genesis E-320 Propane Grill bought a weber genesis 320 in US and need to replace the hose / regulator that it fits to German LP gas cylinders. Which...
Normally, at least on an American grill hose/regulator assembly are a universal fit. And both ends of the hose have female couplings. I would think it would be the same on German Models too. For the connection to the grill, the hose coupling size is 3/8" ID.
May 08, 2011 | Weber Genesis E-320 Propane Grill
How to Clean Weber Gas Grill Lid
you can only use oven cleaner on enameled hood not on the cast painted parts like the body and sides of the hood those you can scrape and vaccum or brush
Jun 28, 2009 | Weber Genesis Silver C Grill
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Weber Genesis Silver B Grill Logo
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
