Question about Garmin nuvi 205W GPS Receiver
Can i put software to use on water or boat - Garmin nuvi 205W GPS Receiver
    President:
  • 1,514 Answers
The answer is yes you can. However remember that your satnav is not waterproof so you must keep it dry. To buy maps for on the water go to www.garmin.com. Hold your mouse over maps and click on BUY MAPS. You'll have to fill in your satnav model, what continent you want to use it in and for WHAT ACTIVITY select ON THE WATER. The maps available for on the water will be shown and you can select which ever you want.
When you're downloading the map download to your computer and install to an SD card rather than to your satnav as you could overwrite the map already installed on your satnav. For details on how to do this go to http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
This explains how to update your maps but also includes downloading to your computer and installing to an SD card.
NOTE: There can be problems with nuvi satnavs reading SD cards so I would advise you to try installing a map you already have to the card first and see how it goes. If you don't have a copy of your map on your computer and you have at sometime in the last few months updated your satnav
  • Log into myGarmin
  • Click on myMaps
  • When you see the map you have installed on the satnav click on DETAILS and it will take you to a page where you can download the map again for a certain length of time after you bought it.
Posted on Nov 06, 2010
Blue hat boat racers,batteries inserted,but propellers do not spin
Put it in water - the two screws on the bottom of the boat act as a safety, the props will only spin when the boat is in the water.
Mar 22, 2015 | Blue Toys
How to fix water leak on the steering arm in a 279 glastron boat out drive
most folks take the boat out of the water.. and use clear silicone caulk where you suspect the leak to be.. let it set up a few hours before you put it back in the water..
Oct 15, 2014 | Boating
I have a 60hp Johnson outboard motor, ran fine in a barrel of water put it on the boat. Put the boat in the water& the motor started but had no power it wouldn't rev up & it wouldn't move the boat& then it...
Check fuel pump diaphragm,could also be stuck needle and seat in carburettor.dont think it is head gasket,would not cause fuel to come out of exhaust.take off carb cover squeeze primer,if fuel comes out of front of carb it is needle and seat.also check if choke is not sticking
Aug 14, 2014 | Boating
How to replace a fuse on a boat
Take the boat out of the water, remove the fuse and replace with an identical one, put back in water and turn on... If that does not work take it to the local marina so they can tell you what type of boat you have then we might be able to help.
Jul 13, 2014 | Audio Players & Recorders
Motor runs good out of water in water no go
quite possibly you need a water pump.
Jul 01, 2014 | Nitro Boating
35 hp mercury
Pices of impeller could be stuck in block,put hand on top of block and feel if it is running hot,blow compressed air into tell tale and see if that helps
May 12, 2014 | Boating
See doo wont start
It should start on land more easily than in the water (no drag on impeller). However, you should not run your boat for more than 10 or 15 seconds dry or you might damage the motor (too much heat build up). If you put a flush kit on your boat you can run it as long as you want in your drive way. We always start are boats on the trailer for a few seconds before launching. It makes the first in the water start a lot easier.
Apr 02, 2010 | Encore Software Kawasaki Jet Ski...
BOAT WONT MOVE WHEN IN REVERSE
how far below the boat is the propeller? Since the boat is fllat in back, you may need bigger proppeller. Check to make sure it is getting plenty of water flow
Jul 07, 2009 | Light Outboard Motor Boat Bass Fishing...
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
Garmin nuvi 205W GPS Receiver Logo
74 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
