The shredder won't turn on to cross cut paper, nor anything else. What I did was turn on the shredder and insert a piece of paper and the shredder stopped. I lifted the handle-- then pushed the handle back down, and it would not finish shredding the paper. I unplugged the unit from the wall, and carefully--so carefully picked out all the paper in the cutters.
Many attempts were made to remove any debrie from the blades and it still won't turn on.
We shredded a lot of name-stickers we get with charitable solicitations and now the shredder is...
(More)
We shredded a lot of name-stickers we get with charitable solicitations and now the shredder is jammed;i.e., it will shred but won't turn off unless I put it on "off". Can it be cleaned somehow? It is an AS*800CD and has worked well until now. Art Humphreys, Pittsburgh, PA
Shreeder runs forward and backward OK but has a tendency to stop feeding paper through blades and...
(More)
Shreeder runs forward and backward OK but has a tendency to stop feeding paper through blades and just runs without feeding additional paper into blades. Direction makes no difference.
Model SH79005. When turned on shredder does not stop. when inserting a single piece of paper...
(More)
Model SH79005. When turned on shredder does not stop. when inserting a single piece of paper shredder stops. Shredder stays on when turned on, in either direction. Almost like a sensor is backwards. shredder is only 8 months old has hardly been used.
looking to get info for replacement gear for staples paper shredder common problem,someone must...
(More)
looking to get info for replacement gear for staples paper shredder common problem,someone must supply this item
My Novitech won't turn on. No jams...just won't turn on. Can't find my instruction book. Any help...
(More)
My Novitech won't turn on. No jams...just won't turn on. Can't find my instruction book. Any help out there?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
