Question about Vacuums
The Orange "ON" indicator light
  • 34 Answers
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Posted on Nov 06, 2010
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Green light but won't start
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Roomba 4220 light says charged but wont turn on
Try resetting
to reset the charging system. You can do this by removing the battery from the robot and unplugging the charger from the wall and robot. Please hold the power button down for 30 seconds. You then should charge the robot....."
Dec 29, 2012 | Vacuums
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Garage door will not stay closed - one sensor is showing a green light and the other one is showing an orange light - i have tried to adjust position with no luck
When the two sensors are completely aligned, both sensor will show green lights. Usually the green light is your sending side and the orange/red side is the receiving side. You can measure the distance from the ground on the sending side and then adjust the receiver end to the same to get you in the general ball park and then fine tune it from there.
Jul 10, 2011 | Vacuums
Electrolux canister, maybe fifteen years old, green light indicating cord is plugged in is not lit, nor will the the vacuum turn on. Model 2100 Omni-flow automatic, number on bottom of unit F14970F. Thank...
The light indicates the vacuum is getting power, not only the cord is plugged in. If there's a break in the cord, other wiring, or bad connections, the light will also not light because the vacuum isn't getting power.
Have it checked over at an authorized Aerus Electrolux shop. The service tech can diagnose and tell you the problem, as well as provide an estimate. There should be no charge for this.
Use the below link to find the store nearest you.
http://www.aerushome.com/storelocator/
Mar 16, 2011 | Vacuums
Vacuum does not have power and indicator light that looks like a plug is lit in red or orange
This light is an indicator that the vacuum is getting power, so there's another problem.
First, turn the dial on top so the smallest dot lines up with the arrow. Then check the after filter beneath the tool caddy. Remove and/or replace if it's dirty. Try the vacuum now. If it still doesn't work, continue.
Turn vacuum off. Detach hose. Turn vacuum on. Does it run without the hose? If not, the control valve assembly inside the vacuum is bad and needs replaced. If it does run without the hose, place palm of hand over opening. Does it run? If it shuts off at this point, the tubes connected to the CVA are probably clogged and need cleaned. Either of these repairs need to be done by an authorized Aerus Electrolux service tech.
Other problems may include bad switches, broken/bad wires/connectors. There is the possibility of a burnt out motor, but it's not likely. The only way to get a definite diagnosis is to take the vacuum to an Aerus Electrolux store and have the tech troubleshoot it.
The nearest store can be found by clicking "store locator" at the bottom of the page on the site below.
aerusonline.com
Jan 04, 2011 | Electrolux Epic 6500 Vacuum
Hoover vacuum cleaner indicators stuck
the sensor is located in the tube that the bag mounts to, if you take the bag off of the unit and have an air compressor handy you can blow out the port hole this should dislodge the particulates that are causing the false reading, there is defintely a clog in the system. let me know if this helps thanks Don the Vacuum Doctor Alb, N.M.
Nov 05, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
