Sylvania m400 super5-kit wire diagram I need a diagram to replace the ballast
2 Suggested Answers
keithmcnab
SOURCE: sylvania t8 96 ballast
sounds like the lamp, try replacing that!!
Posted on May 02, 2012
Wiring diagram for Magnetek hps ballast cat.no.12310-153
All the ballasts I've ever wired have the wiring diagram on the ballast.
I can't find one specific to the Magnetek.
Here's a video -
how to wire ballast 1
Oct 09, 2017 | Garden
How do I wire a ge ballast p.n.532-2995?
Your ballast kit replacement has a diagram in the box. Make sure you get the correct ballast kit. The diagram is pretty complicated, unless you know how to read prints.
Oct 16, 2014 | Home
How to install HID to honda xrm 125
Did you buy a HID bulb or did you buy the kit with the ballast etc? Usually an HID lamp will come with a ballast and wiring loom which is per fitted with relays etc. you would normally plug this loom into the headlight socket of your bike's wiring and then tidy the ballast etc behind the fairing and replacing your bulb with the HID lamp. If you don't have the loom and ballast they're pretty easy to come by on the auction sites.
Jul 14, 2014 | GAS EC 125 Motorcycles
Sylvania t8 96 ballast
May 02, 2012 | Televison & Video
Does each headlight have its own ballast?
each headlight sits in its own bezel and is independently adjustable
Mar 13, 2012 | 1998 Lincoln Mark VIII
I need a replacement ballast and capacitor for a 400W metal halide outside light, I need to know who would carry it and also a wiring diagram
most home depots will have a replacement ballast for this light, inside of box will have the correct wiring diagram, and how to wire it, if not sure as to how to wire it call an electrician
Nov 22, 2011 | Home
How do i wire up hid headlights on 2005 mazda 3
To wire up an HID kit on the low beams of your Mazda 3 2005, you will need 3-4 things:
1- HID kit (bulbs and ballasts)
2- HID relay (connects your hid kit to your battery)
3- 4700uF capacitor (solves DRL flickering issue)
4- H7 hid bulb adaptor (you can also use the rubber piece that holds the bulb wires as a spacer)
Wiring diagram:
http://www.carsets.co.uk/upload/temp/images/hid-light-installation-photo-display.jpg
Tips on How to wire up:
1. HID bulb's amp wires connects with the ballast's amp wires. (There's only one way to connect them.)
2. The positive and the negative spade connectors from the hid relay connect with your vehicle's low beam connector, closest to your battery: the driver side. The passenger side low beam connector is not used and should be insulated. You can use electric tape.)
3. Each ballast is connected to one of the relay's clip connector, and it's grounded on each side to your vehicle's body. (One connector for each ballast, one for each side. You can use the screw for the body as a ground.)
4. The red wire(with the inline fuse) in the relay connects to your battery's positive terminal.
5. The capacitor sits on the relay switch. (Google for how to wire the capacitor onto the hid relay switch.) dynoxg image
6. The halogen bulb sits on an adapter. You can safely remove them from each other, and use an H7 hid adapter instead.
For more help: Moonlight Driving
Nov 06, 2011 | Cars & Trucks
Looking for the wiring diagram for a syvania LU 70 ballast
http://www.lightbulbsurplus.com/index.php?main_page=product_info&cPath=4_16&products_id=285
Under the heading in the middle of the page > 70 Watt HPS Replacement Magnetic Lamp Quad Tap (In blue), click on>
Download Specification Sheet.
This is a PDF file give it a few seconds.
Just in case, here is the direct PDF file link,
http://www.lightbulbsurplus.com/media/data/LU70-MULTI-KIT.pdf
Wiring Diagram H, on the bottom right corner.
Nov 23, 2010 | Hammering
Need wiring diagram for three lamp flouescent fixture using a four lamp electronic ballast
i have a light fixture with two single pin T96 bulbs, black and white wire go to one end of the fixture, two red wires come out of other end - one wire on each socket, but a have a ballast with two blue wires and a red wire coming out the same end of ballast, how do i wire this up? thanks Charlie
Sep 15, 2009 | Kitchen Appliances - Others
How to replace a tube holder or ballast
You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
