Question about GE DBXR463EDWW Electric Dryer
The dryer doesnt heat up to dry clothes - GE DBXR463EDWW Electric Dryer
  • GE Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My dryer DLE 2514W does not dry the clothes enought, we have to put it on for a second time to get them all dry. Seems to be alot of heat but doesnt dry the clothes
disconnect vent hose and run a load of clothes, if they are dry then the vent hose is restricted/clogged. if for some reason it is doing the same then take dryer apart and clean from lint screen back, I am almost certain that it is the vent tube.
Dec 23, 2010 | LG DLE2514 Electric Dryer
My gas dryer heats but doesnt heat correctly, takes along time to dry the clothes
Hello
When the dryer wont dry clothes or won't heat at all it means that the issue is with the Thermostat/Thermal fuse that needs replacement as it has gone bad. Please check the thermostat for continuity as no continuity between its two pins states bad fuse. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Dryers
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
The dryer doesnt get hot enough to dry clothes
Pull the dryer out and remove the lint hose . Turn on the dryer and feel if there is good air flow and if you feel heat . If there is good air flow and heat , dry a load of clothes , to see if they dry normally .
If there is not good air flow , then the blower wheel is probably stripped and needs to be replaced . If there is good air flow and heat , then the problem is in the vent ducting , between the dryer and to where it vents to the outside . Dryer could be pushed back too far , causing the hose to " kink " , restricting the air flow to the outside .
Remember , a dryer either heats or doesn't heat . If no heat , then a dryer problem exists . If heat , but dryer does not dry , then a vent problem is the cause ( except for maytag , which the blower wheel sometimes strips out ) .
Nov 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer end cycly without cloths drying. Doesn't
IF DOESNT HEAT UP ANYTING CHECK THE THERMAL FUSE AND REPLACE IT IF NECESSARY!!!
IF IT DOES HEAT UP A LITTLE IS NOT THE FUSE!! IT COULD BE THE EXHAUST PIPE (DUCT) CHECK THAT IS NOT BLOCKED OR CLOGGED!!!!
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
GE DBXR463EDWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
