In the control box of my GE ac model aew10amg1, there is a long cord that is loose. It is just hanging and I don't know where it goes, if it goes anywhere. I was cleaning and noticed that it was just hanging
2 Suggested Answers
  • 3289 Answers
SOURCE: Have possible mold in window
You should be able to clean the mold from the coils with a bleach and water solution without any concern for damage to the unit. However.. there are products designed for this job. If you insist on using bleach I strongly suggest that you remove the unit from the window and perform the cleaning in an area where the bleach solution can drain out of the unit without dripping on and ruining carpeting, etc. inside or killing plants outdoors.
Below is a reply I gave to someone asking about cleaning coils. You might want to do this too, and these cleaners are designed for the task - and will remove the bleach smell at the same time.
Both the evaporator and condenser coils (inside and outside) can be safely cleaned with products specifically made for the job. Clean evaporator and condenser coils mean more efficient cooling - which means lower operating costs. Cleaning the coils can remove stale or other less desirable odors that originate from your air conditioner. An example of such a cleaner is made by Thermwell which is available at Lowes and other hardware and home improvement stores. There are many different manufacturers of the cleaners - so if this particular brand isn't available at the store you shop, another will do. Different brands and types have different application methods - so you should read and follow the directions on the can. Many of the canned foaming / spray type cleaners are "rinse free" - meaning it is not required to rinse the foam off - as running the unit will allow the condensation that forms of the coils to do the rinsing for you. If you remove the unit an clean outdoors - or driveway, etc. then go ahead and gently rinse with a garden hose. Keep the water from the inside electrical and electronic controls. It should be noted that window / thru the wall types and other non-central air conditioning units should be tilted so that the condensation and chemicals drain outside - not into the house. If your AC hasn't been dripping water inside, it should be fine. Usually all that is needed is to remove the front grill and filter to access the coil. With the unit off (preferably unplugged) spray the foaming cleaner into the coil and let it sit to work on the dirt, grime, mold, nicotine, etc. that has collected on the coil. When the last step of the can's printed directions are complete - the job is done. You can find some helpful videos on Youtube to show how the cleaning is done on the larger, central air type units.
Please rate this reply if it was helpful to you - good luck!
Posted on Aug 12, 2010
Where do the black and white wires with the connector slides go in the electronic control box? AC unit AGH08AJG1
There probably are matching connectors in the control box identified for AC + (black) and AC - (white).
Jul 01, 2014 | GE Heating & Cooling
My dell d820 power on and goes off
Does it immediately shut down? Is the vents and fan free of dust? Does it get hot and shut down? With or without battery? Do you get to a screen?
Dec 03, 2012 | Dell Latitude D820 Notebook
Uniden 6.0 manual
If you don't know the model number of your phone, click here. There's a link titled "How do I know the product name or model number?" Click that, then look for the model number on the list.
Dec 29, 2011 | GE 29897GE1 Corded Phone
My blower on my GE combo heater/ac oil fired won't come on auto.
I am assuming that the red button is you safety switch, there should be a schematic on the door panel of the unit.
Jul 17, 2010 | 2004 Ford F150
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Shaver keeps shorting out. It goes on and off. Hard to shave like that. ;)
If your model is run directly from the cord, you may have a broken wire in the cord. Could also be a loose solder joint where the AC port connects to th circuit board.
If you shaver is rechargeable, you probably have a loose connection inside. Look at the battery terminals and the connection from motor to circuit board for loose connection.
If you find that you need a new cord, you will find one at shaveroutlet.com
Jan 11, 2010 | Wahl Health & Beauty
Replace dial cord on GE Portable AC/DC Radio Model # P4960A
See photo album:
http://www.flickr.com/photos/goggomobil/sets/72157623454498101/
Jun 02, 2009 | GE Audio Players & Recorders
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
