Question about LG WM-2277HW Front Load Washer
LG frontloader washing machine not pumping water out it goes through its cycle but when it needs to pump out water it makes a continunes noise but not pumping
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
stradeteox
  • 88 Answers
SOURCE: LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Posted on Jan 11, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
Washer wont drain lg tromm frontloading washer
You need to isolate the drain pump and check the voltage at the time of the drain cycle. If no voltage is present then you need to check on the control board as it can be a failure of the drive.
If voltage is present but there is no drain action then the valve pump is stuck, choked or faulty.
remove and check: click on : Drain.
Feb 27, 2013 | LG WM2016C
Whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Jun 21, 2010 | Washing Machines
During the spin cycle the washer makes a loud noise and now it wont spin or drain water
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
Apr 15, 2010 | LG WM2496H Front Load
Not washing at all on any cycle
Sorry, sounds like your Circulation Pump is faulty/worn out.
If your machine is not over two or four years old then maybe you have a simple blockage.
If your machine is old, a new pump can be half the price of a new machine.
Hope this helps.
Apr 16, 2009 | LG Dishwashers
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
My simpson esprit 600 is not agitating during wash cycle it only goes one way
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Aug 18, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
239 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
