Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Our baricuda g3 often gets stuck on the main drains in our pool. we have the main drain lines shut off. cant figure out why the cleaner only gets srtuck in that one place
Would this smart ring fit on pretty much all types of drain covers or is this size specific?
Posted on Apr 09, 2013
  • 640 Answers
Since you have already verified that the main drain line is closed, it sounds like you need to install one of the smart ring drain covers below. They are made specifically to work with in ground pool cleaners to prevent them from becoming stuck on the main drain. They are easy to install and should eliminate the problem.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Posted on Mar 31, 2011
My barracuda g3 gets stuck on the drain after working fine since I moved into the house 4 months ago. I have the main drain turned off. I recently got a new diaphram, although it worked for a couple of...
I would first try turning the drain valve off. If it quits getting stuck then maybe that is the solution. If so then maybe you can open the drain valve only slightly and it will still not get stuck. If it gets stuck even with the drain valve off then you guess is as good as mine.
I hope this helps.
Sep 14, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My barracuda gets stuck on pool's drain. This is annoying since I have to be around to watch it and pull it off. Valve to main drain is shut. What else should I do?
There is a ring that you can buy to go over anti-entrapment main drains that will prevent automatic pool cleaners from sticking on the drain. They are designed specifically for this purpose. If you are sure that the main drain in closed, this is going to be the best and cheapest solution.
Jan 28, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The barracuda keeps getting stuck on the main drains. I have tried every different setting to even with no vac on the drains it still gets stuck what to do
Is your main drain closed completely? That is the first thing to check. If the main drain isnt completely closed, that is going to be your problem. If it is the pool cleaner that is causing the problem, there is a ring that you can buy that goes over the main drain to prevent automatic pool cleaners from sticking. You will need to install one of these and it should remedy the problem.
Jan 18, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Stop pool vacuum from staying on main drain
You will need to shut off you main drain. Main drain is a misnomer, it is better called a deep suction as is the Barracuda. They both pick up heavy dirt only the cleaner will go to the dirt. This makes the MD redundent. As an appendege it is not nessary. With suction going through both they will stick together. So with no need for a MD you should shut it off or better yet plug it with an expantion plug. I hope that explains your problem. Simple fix.
Oct 13, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
It gets stuck in the pool drain and wont move
If these pool cleaners are getting stuck on the main drain, it is probably an easy solution. First, make sure that your main drain in closed. Make sure the main drain grate is installed. If the main drain is not flush with the pool, you have an installation problem and you will need to consult with a pool builder about soultuions to fix it.
Aug 18, 2010 | Zodiac Baracuda G3 Automatic In Ground...
POOL CLEANER GETS STUCK ON THE MAIN DRAIN
If it's an older Navigator and it just recently started to hang up on the drain cover, replace the throat assembly, part 29. The lugs or hold offs on the bottom of the assembly have worn down and are not breaking the suction as the Navigator travels over the top of the domed drain cover. Replaced mine and no longer have the "my navigator gets stuck on the main drain" problem.
Aug 06, 2010 | Hayward Navigator Pool Cleaner
I have the zodiac g3 i hear it pulsating but i looks like it has too much suction and it gets stuck and does not move how do i adjust it
You need to use your pool cleaners flow gauge to test for proper flow. Keeping the hose submerged, attach the gauge to the hose and turn on the pump. The red indicator, when viewed from the side, should be at the 3 setting. If the flow is too low, check and clean the pool filter and baskets. If the flow is too high, verify that valves controlling the suction lines are in the correct position, change your flow setting on the Flow Keeper valve, or open the main drain slightly.
Jul 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Stuck barracuda
It is probably not a problem with the shoes. These pool cleaners (and automatic pool cleaners in general) often get stuck on the main drain since the implementation on the new anti-entrapment drains. There is a ring that you can buy that goes on the drain. It is designed specifically for preventing pool cleaners from getting caught on the main drain.
Jun 08, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda always gets stuck on the main drain plug in the inground pool
I have found an inexpensive device that will fix this problem. Go to www.maindrainclipon.com for details.
In addition you can buy an installation tool that allows you to install the device on the existing main drain without getting into the water.
Mar 15, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
429 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
