Question about Garden
The plastic fuel lines on my whipper snipper disintegrated. I have replaced them but does not appear to be getting fuel into the carby. If I put fuel direct into carby it will start but not keep running. I can see the fuel in the fuel lines.
  • Roy Cagle
    Roy Cagle Nov 09, 2010
    Did you relace the primer bulb too? Did you clean the fuel filter inside the tank and the flaky, broken, brittle pieces of old fuel line found commonly there? It's a start.
5 Suggested Answers
evwood
  • 50 Answers
SOURCE: pretensioning starter cord on ryobi whipper snipper.
This was answered in a previous solution
Posted on Jan 03, 2009
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
2strokeguy
  • 183 Answers
SOURCE: need exploded view diagram for a zama carby on a
www.zamacarb.com
Zama has a great website. It will show you where to find the series and model number of your carb, as well as a search engine to find the diagram and parts illustration for your carb.
Posted on Nov 04, 2010
SOURCE: How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Posted on Jan 05, 2012
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
Starts then dies - plastic carb
Sometimes, there is a waxy substance in the fuel tank and fuel lines that is put there by the manufacturer to prevent deterioration during storage. Machines may sit in a store for months / years before getting sold. I would get some fuel cleaner and flush the tank and fuel lines , then put some fresh fuel in the tank. I had to do this with a brand new whipper snipper. Had the same problem.
Feb 22, 2014 | Garden
24 hp sears tractor 48" stalls after 15 minutes
check for rubbish in your injectors and drain fuel tank,also check air inintake to the carby and make sure its clear, it can somtimes suck in grass seeds into the carby, i use a small fuel filter from a whipper snipper and it works well
Nov 16, 2012 | Garden
I have replaced my ryobi whipper snipper fuel lines and now it won't stay running. What have I done wrong?
I have had exactly the same experience, and then also replaced the primer bulb, messed around with the carby mixtures, but so far it will not run for more than about 3 - 5 seconds! I have yet to resolve this problem.
Feb 26, 2011 | Ryobi Garden
I need a brake down manual for a victa T 20 whipper snipper carby. its a plastic walbro carby
Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. It covers metal-bodied models, but the operation is similar. Hope this helps!
Dec 30, 2010 | Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
Hi, can you tell me where each fuel line goes on an older Triton whipper snipper, (both ports on carby are at the same level, one 'big' one 'small' ).thanks....
generally the smaller line is the 'feed' line. It would have the fuel filter attatched to the end in the tank and go directly from tank to carb. The larger line would be the return line and rout from the carb to the primer bulb then to the tank.
If everything is working correctly you would see the fuel be drawn from the tank into the carb then leave the carb into the primer bulb and return to the tank.
Nov 26, 2009 | Garden
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
