My speaker isn't working properly. - Audio Players & Recorders
  • 979 Answers
Hello sir, hi there, usually speakers are replaceable if its not working, if the value of your speakers are quite high, you may need to rewind the voice coil, or find a replacement voice coil for it, much better you need to replace the entire unit. Here are some test to confirm if your speakers are busted. 1. get a double A battery. 2. connect the negative terminal to the negative of the battery using a black wire. 3. connect the positive terminal of the speaker to the positive of the battery intermittently with a red wire. 4. you should hear clicks. no clicks it's busted. replace the driver.
test for voice coil free flow. press gently the cone, and feel the free movement, if you feel friction or scratches, replace the driver.
Posted on Nov 06, 2010
Onkyo surround system. The subwoffer isn't making sound. I've tried all remote settings. No luck though. Any ideas?
Try checking that the wires are properly connected to receiver. Maybe the sub speaker is blown
Mar 12, 2013 | Audio Players & Recorders
2006 FLHTCU no sound
First off, make sure your speaker switch is in the proper position. You would be surprised how many folks come to the shop with the same problem because the switch is in the wrong position! If this isn't the problem, check to make sure the speaker connections are ok. If the radio needs repair, it will have to be sent by your dealer to United Radio. Retail cost for radio repairs is $400 if you don't have extnded warranty.
Jul 10, 2012 | Motorcycles
My Yamaha RX-V563 receiver displays "Check Speaker
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
Oct 03, 2011 | Yamaha RX-V563 Receiver
Only my front speakers work in my 98 chrysler
If this is the original radio, you lasted longer than most. It could be the radio or the rear speakers. Again, if the speakers are original, they lasted a while (13 years isn't bad). If you plan on keeping the car, replacing the radio with a CD unit would be advisable. However, if this is an aftermarket radio that isn't too old, I would check the speakers. They may have blown. There are many cheap replacements that function much better that stock speakers do. They are available online or locally.
Happy Hunting
Aug 13, 2011 | Car Audio & Video
So after getting my car back for the garage my subwoofer isn't working I checked to make sure all of the connections are correct and the settings are there why won't it work
Check to see if your amp is on. You may have blown a fuse somewhere maybe on your amp. Check for proper voltages and make sure the sub isn't blown by pushing on it. If you feel unequal resistance, you probably blew it. Also check the ohms on the woofer.
Jun 06, 2011 | Car Audio & Video
My speakers make no noise in certain games , but the only subwoofer works, speakers work everywhere else though
At the 5.1 and 7.1 sound cards,you have more that 1 socket for speakers.If the jack isn`t plugged into the green one,the speakers will not work in all PC application
Oct 19, 2010 | Logitech X-530 Computer Speakers
Only used a few times and the power is on but nothing showing on the screen and theres no sound its a black ds lite
The reason the screen isn't showing-up is probably because of runny colors or blotchy colors permanently stained on the screen, even when the Nintendo DS Lite is OFF, my guess is that the liquid crystal display (LCD) is cracked. And also, there are multiple reasons for your speakers not working properly. The main reasons for the speakers not working would be the following;
  • Something small must have gotten wedged inside of the speakers.
  • A type of liquid and/or sticky substance leaked into speakers.
  • Lots of pressurized force on upper screen(which could have also caused the damage done to the screen).
What I would recommend is make an appointment with "Nintendo customer service".
Feb 16, 2010 | Nintendo DS Lite Black Console
46 people viewed this question
 Grubhead
Grubhead
