Question about Vacuums
It a rechargeale. It will not charge. is there any way to dismantle it and replace the rechargeable batteries. ? There does not appearto be any screws to separate the two halves of the body. maybe teh
  • 34 Answers
What model...lots of recalled vacuums out there under recall for batteries. Can you solder ? The new batteries WILL have to be soldered. Can you get someone to read voltage of the piece you plug into the wall ?
Posted on Nov 06, 2010
  • richmobile Nov 06, 2010
    the question was about a rechargable hair clipper.
WILL NO CHARGE
The battery is probably no longer rechargeable due to age or to the number of times it has been recharged. If the battery can not be replaced, then the entire vacuum needs to be replaced with a new one.
Aug 02, 2015 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Battery flashing
Normally a battery flashing is an indication that the battery either needs to be replaced or is low and needs to be recharged (if it's rechargeable)
Bear in mind that rechargeable batteries, such as those used in the robot-controlled vacuums do not have an infinite life. There will come a time when it will no longer take (or hold) a charge and have to be replaced. If this is your situation, take the vacuum (along with the charging station) over to a place called "BATTERIES PLUS BULBS" (there are stores all over the US) - these guys can very often rebuild the battery pack for less than half the cost of replacing it.
Good luck!!
Nov 01, 2014 | Vacuums
Battery will not charge
Rechargeable batteries (usually Ni-Cd) have a finite life and after a certain number of recharge cycles (usually 500 times under optimum conditions) will loose their capacity to retain a charge as one or more cells will become 'worn'. Unless your appliance has a 'smart' charger circuit, leaving the appliance always plug-in will greatly reduced the batteries pack life due to overheating/overcgarging.
Unless you can test and replace as required the individual batteries, it may not be a cost effective solution to replace the batteries.
Hope it helps.
Jul 27, 2010 | Black & Decker SPV1800 Handheld Vacuum
Battery does not charge
These batteries are nickel cadium so they do not recharge foever
replace the rechargable batteries to get this working for you
Mar 27, 2010 | Oreck PR8000 Stick Vacuum
When to recharge batter
hi right to be honest both ways are correct, but if your using it every day then its best to put it back on the charger after every use, but the problem with this is that the battery never goes totally flat, so never does a full recharge this reduces the life of the battery by upto 50% so if you are using it regular and need it charged daily then its best to once a month let the battery go totally flat so that it wont even make a sound then do a full recharge.
Doing this will ensure the battery remains at peak performance and make it last longer.
If how ever your only using it say once a week then its best to only charge after the battery has gone flat due to the fact that it would remain on charge longer and cause the battery to over heat reducing the life span of the battery.
But witch ever method you use always let the battery go totally flat once a month then do full recharge this will prolong the life of the battery and ensure it keeps working at full power.
Let me know if you have further questions ok
Jan 18, 2010 | Euro-Pro Shark Cordless Stick Vacuum...
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
Oreck Electrikbroom (battery) won't hold charge and pick up dirt.
Battery needs to be replaced. All rechargeable batteries have limited recharge cycles. NiCad's are usually used in these and also develop "memory' which keeps them from recharging fully.
Contact Oreck or reputable dealer for replacement.
Nov 15, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Rechargeable battery does not recharge
They are nickel cadminum batteries, and are replaceable, you may have to order from a repair shop, or go thehooverstore.com. Once you have the battery pack out, maybe you can find them like at Radio Shack or other places that sell these type packs,
Oct 15, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
