Model pixma mp 500. paper prit size always reverts to 4" x6" when mach. is switched off. wish to have 8"x 11" as standard.
  • 13,433 Answers
Set the size on the computer side, set it as default so it shouldn't change.
Posted on Jun 14, 2008
  • Ekse Jun 14, 2008
    todo this
    press start -> printers and faxes -> right click your priter -> printing preferences -> paper and quality -> there you go.
Black lines on print, new printer
Go to the settings on your computer hit properties and do an alignment, sometimes if you take out the ink cartridge and put it back in it will say do you want to do an alighment, then after the page prints you have to scan it, then pick which one looks the best
Jan 28, 2014 | Canon PIXMA PRO-10 Professional Photo...
Scanner not scanning right. scans in sections. i need to scan a standard size sheet of paper and it scans it in peices. how do i get it to scan this document correctly
You need to set the scanner to scan a standard size paper (letter or A4) in the Scan Settings dialog. To get there, from the MP Navigator select "Scan Photo/Document", then on the lower left side of the preview area click on the "Specify. ." button. Your Document Size is probably set at "Auto Detect (Multiple Documents)". Change this to the size document you are scanning and click "OK". Now you can preview and scan and not have segmented images.
Mar 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP160 Printer/Scanner not working after move.
Check the paper out sensor and clean the same may solve your problem.
Revert back for more assistance.
Jan 20, 2010 | Canon PIXMA MP160 All-In-One Printer
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
I have 4 x6 printer paper and the printer only shows standard 81/2 by 11
If you use windows photo gallery to print, it will allow you to set the paper size and type, otherwise in your control panel/printers and printing preferences you can set the 4x6 paper size.
Oct 02, 2009 | Canon i860 InkJet Photo Printer
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
Scanning Photos using ADF
Under the MP Navigator software, go to Platen scanning, then under the Document Size box on the left side, click the "specify" button. Then switch document size from "auto-detect" to 4x6 portrait or 4x6 landscape. Select "ok" and that should do it. Make sure you line the photo up correctly on the platen.
Nov 16, 2008 | Canon PIXMA MX310 All-In-One Printer
How to print 3 3/4 x 6 3/4 sized paper
I found the solution myself. 1. Open Canon MP Printer 2. Select "Printing Preference" 3. Click Page setup 4. Click "Custom" 5. Select "Portrait" 6. Select Normal size printing 7. Adjust Paper Holder to fit small sized paper
Feb 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
42 people viewed this question
jasbo
jasbo
