Question about Mach Speed Eclipse 180SL 4GB MP4 ECLIPSE180SL4GB Motherboard
How do I transfer or create a playlist onto my Eclipse 180 mp3 player?
2 Suggested Answers
inbarrose
  • 118 Answers
SOURCE: My Eclipse 180 Mp3 media
remove battery and try again, if this does not fix the problem, you might have to reset the device, by pressing the power button for a long time while turning the device on instead of once. then following the instructions reset the device.
you may have to download and install new drivers for the device from the internet after the reset.
you will possibly lose your data stored on the device.
Posted on Mar 26, 2011
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
May 11, 2010 | Coby MP-610 MP3 Player
My mp3 player is telling me that my location is unavailable. and that it might have been moved to a different location, what does this mean, it won't let me download any music onto it and it's just being...
Using Windows Media Player 11 for transfers,
0. setup your Library > Add to Library... [Open Advanced Options]
add a location on the computer media is saved you want to use for making playlists and synchronizing
1. create a playlist in Library or Sync
2. synchronize the created playlist in Sync
I'd appreciate your vote if this was helpful.
When needing more help just add a comment.
Apr 14, 2010 | Coby MP-610 MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
I want to create folders for different types of music. Ho do I do that?
If you want to create folders on your computer to "drop" your types of music into, then you can choose "My Computer", select the disk drive for your mp3 player, then simply right click & select "New", then "Folder", & name it. Then you can drag & drop the music into that folder, which will load it onto your mp3 player as well. BUT, if it does not recognize them as separate lists on the mp3 player itself, then you have to use the EasyRip Module Dock to manage your playlists, where you can move specific songs into a list & save it. OR, if you use Window Media Player, create your playlists there & save them, & typically that will transfer as a playlist for you under the EasyRip Module Dock as well.
Various ways to do the same thing, depending on what you want. Hope this helps!!!
Dec 28, 2008 | RCA M4208 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Unable to transfer playlist to sansa c250 mp3 player
This player isn't capable of playlist transfer - you can only create a playlist on the go from the player itself. You will have to transfer individual songs only.
-Tha Mp3 Doctor
Dec 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Transferring songlists
Click on Menu of Samusung media studio - import files - choose I-tunes folders
Jul 25, 2008 | Samsung YP-U3 MP3 Player
My playlist won't load to the mp3 player
Model number? Manufacturer name? Here's generic advice: use Windows Media Player 11 to transfer.
Here's more generic advice: turn ON automatic synchronization (if your mp3 player is a Philips, esp)
Here's more generic advice that can be applied to many mp3 players:
If users of X20 want to create playlist, please change connection type as MTP.
( X20 -> Setting -> Advanced -> Connection Type )
After then, you can create playlist with WMP11.
For more information on creating playlist?
Please click here " How to create playlist with WMP11"
http://www.iriver.com/support/faq_list.asp?searchProductIdx
Jun 09, 2008 | Audio Players & Recorders
Mach Speed Eclipse 180SL 4GB MP4  ECLIPSE180SL4GB Motherboard Logo
1,446 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
