Question about Sears Grinders
Im looking for a grinder to sharpen shears, im a barber
    Brigadier General:
  • 4,088 Answers
You need a small variable speed grinder that has a fine grit stone on it. A regular bench grinder will ruin a pair of shears in short time. Look for one at Sears and explain your needs. Good luck!
Posted on Jan 10, 2011
What are some Steps To Sharpen Meat Grinder Blades?
Are you craving for burgers or delicious hot dogs? But, your meat grinder is failing you every time you want to make patty for your burgers or sausages. This might be the result of having blunt blades. Meat grinders fail to work efficiently if you do not sharpen meat grinder blades consistently.Click the link for full details Sharpen Meat Grinder Blades in Quick Smart Ways
Apr 14, 2018 | Kitchen Appliances - Others
Tip
Sharpening your garden pruning shears
Every so often you will find that your gardening shears just aren't up to snuff. This will usually be most prominent when it get really difficult to cut through even the weakest of branches. Cleaning and sharpening your pruning shears is very simple and can be done in a matter of minutes.
To start you have to make sure that your shears are clean. Its not difficult to clean them, you can use a cleaning solution like scrubbing bubbles to get the dirt off, you just spray them and wipe them off with a soft cloth. If there is a lot of dirt or rust on the blade you might need to use a wire brush or a piece of steal wool to get them clean.
When you are satisfied with how clean the shears are you will need to get a sharpening stone. Carefully using your thumb on the convex blade (the big side of the shear) of the shears find the beveled edge. This will tell you the angle that you should be using to run the stone along the edge at.
When you have identified the angle that you're going to use to sharpen at, take the stone in your dominant hand and in the other hold the shears open. Applying a little bit of pressure rub the stone in small circles. You don't want to over do it, just a few times should be enough to get the blade sharp again.
The beveled edge should be the only blade that needs to be sharpened. On the flip side of the balde you shouldn't need to sharpen because it should be flat. In the case that you run your finger along the flat side and you find a bump you can use your stone to just smooth it out.
When you are satified with how smooth the blade sides are you should put a little bit of oil into the joint of the blades and open and close the blades a few times to get the oil into the gears. And finally using a cloth wipe the oil up and spread it over the blades. Wiping the oil over the blades will help to keep them from getting rusty.
To make sure that are ready to use you can test them on a piece of shrubbery or you can just head back out to the garden and get to work!
on Feb 05, 2014 | Garden
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Need user manual for utility sharpener 21170
http://www.hammerwall.com/Manuals/Craftsman/Description/152.211700/Craftsman%20Utility%20Sharpener/L0804165/
Mar 20, 2014 | Craftsman Utility Sharpener
How do I sharpen my pruning shears?
You can use a mill file to sharpen your shears fairly easily. See this instructable page. Sharpen Hedge Shears with File
Jan 28, 2014 | Garden
I want to sharpen toenail clippers
It wil cost more than the clippers them selves,but generally anything with a blade like that can be sharpened. Try going to your local hair salon/barber and asking them who the use to get ther shears and scissors sharpened.
May 06, 2009 | Black & Decker Welding Tools
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
I am looking for a blade sharpener for the a5 blades
Ry`s Barber supply.com has blades for you oster.
May 04, 2008 | Oster 76076-010 Hair Trimmer
Grinders Logo
114 people viewed this question
Top Sears Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
bob walter
bob walter
Level 1 Expert
Are you a Sears Grinder Expert? Answer questions, earn points and help others
