My Windows 7 Screen Has Blacked out. No icons. No anything. No below bar,Which the StartUp menu is. I can't seem to find and solutions online. Hoping one of you great Computer experts help me :D.
  • Mohammed Ebrahim M
    Mohammed Ebrahim M Nov 06, 2010
    Are u able to login to your computer???
    Scholar:
  • 85 Answers
Press Ctrl+shift+Esc key the task manager will open there click the New task button and type explorer.exe and give OK. The issue will get fixed.
Posted on Nov 06, 2010
What's the solution for the long black background with crusader on startup windows 7 ?
Click Start and type msconfig into the search bar->load msconfig->go to startup->untick all the unnecessary tasks.
Next try updating your graphics driver, use driver booster from majorgeeks if you're not sure how.
If this doesn't work use IObit Advanced system care to clean your system.
Failing that, reinstall windows and start again.
failing that get a SSD drive or new harddrive compatible for your system
Jun 21, 2014 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
When I turn on the computer, it has a gray screen with a loading bar that says "Windows is loading files". And then, it doesn't ever move from that screen. Help?
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 08, 2012 | HP Omni 120-1125 20" All-in-One Desktop PC
Bootmrg is missing
I suggest that you perform a Startup Repair.
Method 1: Startup Repair
1. Please insert the Windows Vista/7 DVD and reboot the computer.
2. When we are prompted to press a key to boot from the DVD, please press Enter or the space bar.
3. Choose your language settings, and then click Next.
4. Click Repair your computer.
5. Select the operating system you want to repair, and then click Next.
6. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Access the link below for more information about startup repair:
http://windowshelp.microsoft.com/Windows/en-US/help/5c59f8c1-b0d1-4f1a-af55-74f3922f3f351033.mspx
You can also try "Rebuild BCD".
Method 2: Rebuild BCD
1. Put the Windows Vista/7 installation disc in the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. (Click the operating system that you want to repair), and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type bcdboot c:\windows /l en-us, and then press ENTER.
Note: C:\ should be changed to the default partition you installed Windows Vista/7.
http://support.microsoft.com/kb/927392
Oct 03, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Dell latitude D610 will not unmute
    • 1 Click on the speaker icon in the system tray of your windows 7 screen, located in the task tray by the system clock. This will cause a volume adjustment screen to pop up. Drag the volume slider to adjust the volume higher or lower.
    • 2
      Right-click on the speaker icon and select "Open Volume Mixer" to manually adjust the volume of each device separately, using the same method as in step 1.
    • 3
      Right-click the speaker icon and select "Sounds" to change which sounds play for specific events, such as Windows Startup, Windows Logon and System Notification. This should bring you directly to the "Sounds" tab of the sound menu, where you can click the program event from the list and change the sound using the drop-down menu at the bottom. You can choose "(None)" to disable the sound.
      car headlights.
Jun 01, 2012 | Dell Latitude D610 Notebook
Have lost internet explorer icon at bottom left of screen
Not enough information,,do u mean u lost IE icon in Windows 7 OS task bar? or lost icon from startup menu?
You can pin the icon back to taskbar in win 7 by:
go thru the below link
http://www.sevenforums.com/tutorials/397-taskbar-pin-unpin-program-links.html
Jan 06, 2011 | Acer Computers & Internet
All icons are now in wordpad with lnk instead of exe. I have tried several downloads and do not seem to work. Icons are square with symbol wordpad. OS windows 7
Please try, Click 'View' in the menu tab ---Then select the 'Toolbar' option this should enable the tabs in the menu bar
Apr 17, 2010 | Dell Computers & Internet
On my pc not any icon or start menu can be shown only wallpaper can be here
To solve this issue..
1) Click CTRL+ ALT + DEL at a time..
2) You will find Task manager option..
3) From that select process tab..
4) Then select explorer.exe...  And select end process..
5) Then select application tab...
6) And click o new task..
7) In the bar type explorer.exe..
8) Then select ok..
Now the icons will be reloaded.
Jan 02, 2010 | Microsoft Windows XP Professional
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
