Question about Apple iPod touch
My ipod wont let me click on anything, it is like it is frozen
  • 881 Answers
Press and hold the HOME and POWER buttons at the same time to force restart your iPod touch.
Posted on Nov 06, 2010
4 Suggested Answers
SOURCE: ipods
thank you for the suggestion of holding menu and cenre button...it worked!!!!
Posted on Apr 29, 2008
jazzyboy11
  • 728 Answers
SOURCE: IPOD FROZEN
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Posted on Apr 07, 2009
mneilsen2084
  • 342 Answers
SOURCE: frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Posted on May 06, 2009
I have a ipod touch that wont turn on even with charger attached it will not do anything
weell technically it is frozen so you have to wait a few days then turn it back on
Mar 21, 2010 | Apple iPod touch
IPOD FROZEN
Apr 07, 2009 | Apple iPod nano
Ipod nano 4 gb is frozen
Press and hold the center button and the menu button at the same time. This will reboot your Ipod.
Dec 22, 2008 | Apple iPod nano
Ipod wont scroll
it wont do anything!!
May 30, 2008 | Apple iPod touch
Ipod 30gb video black
Try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 15, 2008 | Apple iPod MA446LL/A MP3 Player
Its frozen it wont do anything ive tried everthing and it wont work
My IPOD is frozen and when I plug it into Itunes it says it is corrupt.
Apr 17, 2008 | Audio Players & Recorders
IPod Nano 3rd Gen. Frozen on main screen. will restart (menu+select) but goes back to being frozen on main screen help asap pleaase
yes it can if it will load in to my computer? look for divce g right click and format it you will lose every thing but it should solve your problem when done use itunes to restore settings ? let me no how you get on
Jan 24, 2008 | Apple iPod nano 3rd Generation
My ipod nano wont do anything
umm im not sure if this will work but you could try holding menu center button untill the apple comes up (this may not work if ipod has not got any power to run)
Feb 22, 2007 | Apple iPod nano
Apple iPod touch Logo
121 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
