Question about Averatec 3200 Notebook
Avertec 3200 notebook
Reformatted hd & installed xp home. reset cmos to boot from hd ------ black screen with cursor.
  • 790 Answers
Remove the cmos battery from the board and replace it again!!
Posted on Jun 14, 2008
My HD crashed. I replaced it with a new one. I cleared the BIOS by disconnect and reconnect the MB battery. When I try to reinstall the OS (XP, Vista and windows), it got to the point where it...
I had a similar problem to this when installing windows 7 to my netbook with an external DVD drive.
I discovered that after getting to a certain point of the installation where it reboots, to remove the DVD for the installation of windows, so that it can proceed with the installation, instead of trying to partition and reformat the drive again which it does when the disc is in the drive.
It sounds, however, that your problem may be different than the problem I had. But, I thought I would share this with you.
Aug 21, 2010 | Sony VAIO VGN-C140G/B Notebook
Avertec 2300 will only power on to a black screen and says Read disk error, press control alt, delete to reset, but when you do this the same thing apears over and over, Will not take any disk windows or...
Sorry, a Read Disk error means the disk is dead or dying. At a minimum, you have to reformat it and reinstall Windows. If it doesn't reformat, then you need a new hard drive.
Oct 27, 2009 | Averatec 3200 Notebook
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Black screen with flashing cursor
It may be because of your hard disk damage or OS problem. Try to install a fresh copy of XP from a cd. boot from XP cd and install .
Apr 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Avertec 3200 won't reboot, white screen says NTDLR is missing
Ooops, if ntldr is missing, it means your operating system is dead. You should reinstall windows from cd. Must get into Bios to select first boot device as Cd and then press f10 and yes. When you start your lap it says you what key press to get to Bios or boot menager.
Mar 26, 2009 | Averatec 3200 Notebook
Hook up Avertec 3200 to Sharp Aqueous TV
After I found the manual somewhere on the internet, I realized that it is already available here. (Lucky you!)
I could not find a specific manual for your Aquos TV (which model?). Look into your manual, and see if there is an option to connect via VGA of HDMI for video
If you want to use your TV speakers, it depends what audio input options you have on your TV. You might need a cable like this:
The red/white connectors into your TV, the 2.5mm plug into your computer.
Jan 11, 2009 | Averatec 3200 Notebook
Laptop wont boot up
It seems ur OS gets corrupted...try to boot from bootable xp cd and re install again...
Dec 04, 2008 | Gateway 450ROG Notebook
Suddenly my Averatec won't start
It could be your Power Supply or your CMOS Battery is dead. For Power Supply, you can test by try to connect your Power Cord without battery to see for any PowerPush. If it is still not on then you can check your CMOS Battery for any failure by test the good one from other similar laptop since you had two. I hope this help.
Apr 22, 2007 | Averatec 3200 Notebook
Ax480 boot issue
if u haven't overclocked it yet (goes easy to 2.4 to 2.6 some more, don;t go over 1.7V though) then you should single out the problem part by booting with: 1) try 1 memory stick only 2) safe mode 3) only necessary cards, possibly gr.card only now as we all know the quality of Microsofts products, try installing a fresh copy of your legal windows OS on any other disk or even the same with the separate installation option if you must. Simply, there is no better way to find the problem. Windows xp is rather funny lately with its updates... Good luck m8
Jan 13, 2007 | AMD MB TUL | AX480A-GF XPRESS200P RT...
Averatec 3200 Notebook Logo
134 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
