Question about Panasonic DMRES20D DVD Recorder
No Sound I've plugged in every cable correctly and the picture is perfect but there is no sound. Our old freeview box has perfect sound so its not the aerial. What's wrong with it?
  • d0cphil Sep 28, 2008
    I have the same problem. The recorder was working last week and one day i switched on and no more sound from freeview or from cable box plugged into the SCART IN socket.
    The strange thing is that I still get sound when playing a DVD. So i know my connections are ok.
    Any ideas?
    Problem Solver:
  • 5 Answers
Presumably you have already tried powering off for 10 mins then doing a shipping condition reset ?
Posted on Mar 05, 2009
What weight is this TV? I'm wanting to get a TV wall bracket so I can put this on to the wall. As this is an old TV and has no Freeview is there a way of connecting/getting Freeview to work
Yes there is a way buy a freeview box with a legacy scart plug connect to TV with a scart lead and use the freeview box remote to change the channel on the decoder and have the av input for the decoder on the TV and use the TV as a monitor only
as to the weight and how to mount the TV type and model would be helpful
Jan 22, 2017 | Televison & Video
Screen on Philips Flatscreen HD has turned green there is sound on all Freeview stations only, no picture but DVD player works perfectly well and in full colour Why is this and what needs fixing. Freeview...
If the hookup is HD from a box you have Green(video) Blue and red--check first they are connected properly at both ends. Component would also use two more cables for audio.
If HDMI maybe a bad cable or issue there. HDMI has issues with and creating no sound problems.
If a DVD player does work fine it means a hookup issue of some kind or a very odd problem in the set(unlikely).
SD TECH
If using HDMI at least attempt a component hookup.
Apr 22, 2012 | Televison & Video
Hi there! I have a 19" Beko Tv about 4 years old. The sound has gone altogether. Picture good though. We have it attached to a freeview top box. Husband saying its the topbox that's faulty. ...
I assume that you have attached it via SCART cable...since SCART plugs have 21 pins, and carry video, audio and switching signals ,sometimes a bad connection on either TV side or Top Box side ,the sound goes off first..Make sure your SCART plugs securely fit to either side.
If it does not help pls visit the URL below for further advise before going to blame the Top Box....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Set-top Box Connection Advisor This page is designed to help you with connecting your Freeview, BT Vision, Virgin Cable, Freesat or Sky satellite set-top box to your home TV system. http://www.radioandtelly.co.uk/connecthelp.php
Feb 02, 2011 | Beko 324250WN 28" TV
"snow sound" on rca tv, perfect picture
Although your picture is perfect, I would think the fine tuning is slightly off. This can also be to do with the cable box frequency setting. Call out the cable people & get them to check the box & the setting up to the TV.
Aug 24, 2009 | RCA F27442 27" TV
Nintendo 64 - sound not working on new TV
Because the 64 is somewhat old I would suggest getting an aerial splitter because the system may not be able to function properly with out it. Try it and see how it turns out. Or, if you don't mind, you could play that game on the computer if you have one. Download Project64 from:
www.pj64-emu.com/
Nov 11, 2008 | Nintendo 64 Console
No sound between freeview hd box and home theatre system
First of all make sure the audio out jacks on your freeview are securely plugged in and routed to the proper input jacks on your surround sound unit and the correct input source is selected on the sourround sound unit. If all is well with this you can test if the surrond sound unit is functioning properly buy turning the volume up half way on the unit. Unplug the right and left cables from your freview and leave the other ends plugged into your surround sound(with the volume up half way). Now touch the tip of the right side cable with your finger tip. the right speakers should hum. And then touch the tip of the left plug and the left speakers should hum. If you get no hum you either have the wrong input source selected on the surround device or the is a problem with it. If the surround sound device is functioning with another device properly, disconnect the cable from that device( ex.dvd,cable,vcr, ect,...) and connect those cables to the output on your freeview. If you still do not get sound, make sure the volume is not muted somehow on your freeview. As you have now connected a verified audio input to your surround sound directly to your freeview and made sure the freeview was not in anyway muted there is a problem with the audio out on your freeview. I hope this helped you solve your problem but if nor feel free to contact me before rating this solution and I will walk you through everything and make sure we get this problem isolated or ultimately fixed.
You can send me your number to my e-mail addresss which is my user name @gmail.com and I will call you free , I have skype and yahoo phone so it will only cost me pennies. I just want to make sure your problem gets fixed for you.
George
Jul 26, 2008 | Panasonic Audio Players & Recorders
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Setting up my freeview box- NO CHANNELS FOUND
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Dec 11, 2007 | Televison & Video
No sound
If I remember correctly, this model can only have sound from either the SCART or the standard input. The solution for this set is to have all the devices work through a common A/V switch box.
The best solution is to update the set to one with more active inputs that are adequate for your needs.
Jerry G.
Nov 19, 2006 | Sony KV-32S26 32" TV
Panasonic DMRES20D DVD Recorder Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
