Question about Eiki EIP-2500 Multimedia Projector
I have both the stand by and lamp indicators flashing then the lamp liight goes to a red The lamp never actually lights up in this time.The globe has only done about 250 hrs.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
The bearing of the colourwheel is locked. No rotation of colourwheel possible, then also no lamp ignition. Colourwheel has to be replaced.
Posted on Apr 17, 2014
No pic or sound on tv Red liight flashing on tv. No response from remote. ?
You did not list Brand or Model number for your product. There are hundreds of brands and red flashing lights usually indicate a fault or failure using a blink code, More information is required to process your inquiry.
Thanks
Jotvguy
Mar 05, 2013 | Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
hello if the lamp cover is not mounted securely the self diagnostic function works and the power /standby indicator flashes 3 times when you've corrected it power/standby indicator goes out the tv enters standby mode
shaun
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hi there
turn set on with lamp in and lamp cover also,and after tryin to tur on ,red ligh its going to start flashing a segment of times.
Let me know how many times is blinling?
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Eiki EIP-2500 Multimedia Projector Logo
49 people viewed this question
Top Eiki Office Equipment & Supplies Experts
Jaime Hernandez
Mohamad Abdan
Mohamad Abdan
neOen
Level 1 Expert
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
