Question about Porter Cable 16 - Gauge Finish Brad Nailer Kit
I have a 16 gauge finish nailer. This nails do not feed to the tip of the gun and you have to push the nails to the tip after each firing
  • 10,865 Answers
Hello Michael. Let's begin with the nails you are using. If you have 15 gauge nails and you are putting them through a 16 gauge gun, they will not feed correctly because they are too large. Also, get finish nails designed for your gun. Ideally use Porter Cable nails but if not at least nails that list porter cable as one of the guns that they are compatible with.
Next, get a can of a penetrating lubricant called WD-40 and some cotton swabs. Disconnect the gun from power and also remove any brads that are in it. Then spray the entire chute and the sprin mechanism with a heavy coating of the penetrating lubricant and let it sit for 8 hours. After it sits spray it again and use the cotton swabs to remove and rust, corrosion, dirt, etc. Spray it again. Then load it up again making sure that you are using brads designed for your gun. Hook it up and try it. IF it is still not feeding as it should checked for other causes such as:
  • magazine is bent.
  • loader springs bent, worn, or kinked.
  • guide channel is too narrow.
  • guide is broken.
The most common ways that magazines become bent is through misuse. Workmen will often use the magazine of the nailer to "set their work." That's a nice way of saying that they use their nailer like a hammer and really beat it up.
Over time, this kind of use will bend the magazine and increasingly slow the guide until it doesn't move at all. A bent magazine should go to a shop and/or be replaced. Magazines can be especially difficult to reassemble, depending on the brand.
Check the loader springs for damage, and replace any that need replacing. Porter Cable makes a repair kit for this purpose.
If the guide channel has become too narrow, they can often becarefully widened by wedging a screwdriver between the groves and leveraging a little pressure to spread the groove.
Joe
4 thumbs up please. ty.
Posted on Nov 06, 2010
Bostitch troubleshooting
Are you using 18 gauge or 16 gauge nails?
Aug 17, 2014 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Gun fires mor than one nail at a time porter cable model da 250a 15 ga. finish nailer
There are two issues that people have with nailers that sound the same however are totally different. Firing more that one nail at a time can be taken as; two nails being driven with one fire or the nailer vary rapidly firing a second time almost instantly after firing the first nail and each time only drive one nail. Problem of double fire (either type) is very common with nailers (the gun very quickly fires twice), however two nails at once can only happen if the wrong gauge nails are used in the gun. A 15 g nailer can very easily pass two 18 g nails or, with more difficulty, pass two 16g nails. To help prevent the driver blade from hitting two nail heads at once, most drivers are slightly tapered at the tip so that the driver will hit the first nail and the tapered part will push the other nails back into the rails slightly. Remove the head of the nailer and pull out the driver. Measure or compare the thickness of the driver to the thickness of the nail head. If you are sure that you are using 15 gauge nails, check the driver for taper. The tapered part should face the rails. If not tapered, try carefully grinding a taper keeping the tip cool so that you do not effect the hardness. You could also check for other brands of 15 g nails with slightly more spacing between the nails. There is a big difference in quality among brands of nails. Good luck with your repair
Jun 01, 2011 | Porter Cable FactoryReconditioned DA250BR...
My nail gun miss fires. seems there is not enough tension pushing the nails forward
Could be that the driver is not returning to top of the cylinder. Easy test, when the gun miss fires, remove air line, with thin metal, insert thru nose and push driver up. Retest gun. If driver was down a bit then nails will not feed. Remove head and check that driver oring is making good seal, lubed, and is not too tight or bent. Also check that lower bumper is not cracked or missing pieces. Replace parts as needed. If driver was all the way up, clean rails and pusher assembly with wd40 and follow with good cleaning with air. If pusher and rails working properly, must be problem with bad batch of nails, slightly thicker or wider head not allowing nail to easily slide. Open nose latch and check that nails slide thru easily.
May 10, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
With the finish pro 35 can you use any 15 gauge strip of nails,glued or plastic strip
i believe that gun takes 16 gauge nails, and yes, all 16 gauge nails are the same, as long as they are strait, not angled
Mar 21, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Dewalt cordless nail gun fires but doesn't seem to feed the nails very well, alot of misfires.
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Sep 25, 2009 | Dewalt DC616kn 18 - volt 16 - gauge...
Nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Jun 05, 2009 | Dewalt D51256K 16 gauge finish nailer kit
I have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Sep 18, 2008 | Dewalt DC616kn 18 - volt 16 - gauge...
Porter Cable 16 - Gauge Finish Brad Nailer Kit Logo
274 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
