Question about Husqvarna Designer I
I have a brother pr600 and I keep getting an error that says "check upper and bobbin thread" Everything is threaded correctly, but when it starts doing this there are loops on the back of the project. What would be causing this?
  • 15 Answers
Mine was skipping stitches. Turned out to be a bent needle! Now it is working great!
Posted on Jan 03, 2013
SOURCE: Upper Thread Error
there could be thread caught in the tension disc in the top of the machine you can get the cover off to clear the thread but it is a bit tricky to get back on
Posted on Dec 06, 2007
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
SOURCE: brother ls2125 bobbin not picking up thread
you have the wrong size bobbin in ,its to high over the bobbin case causing it to rap around the bobbin.
Posted on Feb 10, 2009
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
Why is my Brother SQ9185 Sewing Machine thread bunching up on the back side of the fabric?
That is called thread nesting or bird nesting. Usually it is because it is threaded incorrectly (sometimes the thread jumps out of a thread guide or the take-up lever), the upper thread is not seated in the tension disk, or the upper tension is incorrect.
First thing, install a brand new needle.
Second, remove the upper thread, RAISE the presser foot and rethread from the beginning--make sure the correct thread path is followed.
Third, check that the upper tension is set at the midway point between high & low number.
Test. Adjust the upper tension as needed. Re-test. Tension is correct when the upper and bobbin threads meet in the middle of the fabric.
need elp with tension on singer cg550
Apr 07, 2016 | Brother Sewing Machines
I'm using Brother Poly thread on my Brother PE-770. Everything was fine until I changed needles. I followed the directions exactly. But now, when I embroider, my thread keeps unraveling and the needle...
Please check your needle position, putting it in backwards is a very common error, the FLAT side of the needle shank should be towards the back. Also be sure that during the transition, that the bobbin thread did not get misaligned.
So, make sure the needle has the flat side to the back, and rethread your bobbin thread through making sure it is correct.
Jun 11, 2014 | Sewing Machines
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Question about a bobbin
First you have to determine if the thread under the plate is the bobbin's thread... or just great loops from the upper thread.
Bobbin snarls are caused by the bobbin unspooling in the wrong direction.
Burrs and snags on the carrier.
Upper thread snarls in the bobbin area are "operator error" Typically, upper thread not threaded correctly (foot UP, buttercup)... or neglecting to put the presserfoot down while sewing.
Good luck.
Nov 16, 2012 | Brother Sewing Machines
I am using my new brother CS-60001 sewing machine for the first time and I can't stop the bobbin thread from tangling. I feel the machine is threaded correctly, the bobbin thread is tightly wound and...
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Sep 06, 2011 | Brother CS6000i Computerized Sewing...
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
The upper thread keeps getting caught under the bobbin casing when sewing. The machine will stich, but when I pull it out there 3 threads pulling out instead of the 2 there should be. I have read the...
Other than your machine being out of time and needing service, following are suggestions to try:
Be sure to use the correct type of needle for the thread and fabric you are sewing, ie sharp, top-stitch, embroidery, universal, or microtex for woven fabrics and ball-point needle for fine knits.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Check that the bobbin is turning the correct direction in the bobbin case and the bobbin case is properly threaded.
Set the top tension to the midway point.
Re-test your machine and tweak the top tension so the top and bobbin threads meet in the middle of the fabric.
If the thread continues to hang up, take your machine for service and adjustment.
Jul 27, 2017 | Brother CS-6000
Brother PR600 embroidery machine has decided it won't thread any longer, had a wiper error which I cleared but the machine now won't thread the needles?
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Jun 11, 2008 | Husqvarna Designer I
Sewing Machines Logo
540 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
