Question about Traulsen Reach in Freezer - G22010
How to adjust freeser temperature-traulsen freezer G20010
  • Traulsen Master
  • 1,183 Answers
Posted on Feb 28, 2011
How do I fix the temperature on my Traulsen Model G22010 freezer: it is at 14 degrees and I want it to be 0 degrees
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/TR35924%20Owners%20Manual%20Quick%20Guide.pdf. Check out page 2 to see if these instructions will help with resetting the control.
Dec 24, 2015 | Traulsen Freezers
My traulsen refrigerator is warm not cold
the pump unit is burn
or you have a leakage on the cooling fluid !!
all your dealer and ask the sometime the answer those question with no charge $$ !
Apr 05, 2015 | Traulsen RDT332NUT-FHS Reach In...
Traulsen commercial freezer temperature cannot be set
Don't set hi and low. Set the "Set point" number. That is what it functions on.
Feb 25, 2013 | Traulsen Reach in Freezer - G22010
How do i adjust the temp setting on a traulsen G22010 freezer bought it used do not have a manual
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/TR35924%20Owners%20Manual%20Quick%20Guide.pdf. try steps on page 2 to see if that will help. Not user friendly so take your time.
Aug 07, 2012 | Traulsen Reach in Freezer - G22010
What temperature should a traulsen freezer model G22010 be set
depends on what you are storing. usually bout 0. If ice cream, usually about -10.
Sep 22, 2011 | Traulsen Reach in Freezer - G22010
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Jan 07, 2010 | Traulsen 46 cu. ft. Upright Freezer G22011
Traulsen Reach in Freezer - G22010 Logo
643 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
