Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Clock not bright - Jenn-Air SCE30600 Slide-In Electric Kitchen Range
    Guru:
  • 310 Answers
We rebuild a lot of this part for the dim display problem. This will save you some money!
fixyourboard.com/boards/71001799.html
Posted on Nov 06, 2010
How replace a dash clock light in 2007 kia optima lx the clock works but it is very hard to see the time
I don't know how to access the clock - just wanted to suggest the clock might be ok and just need a new bulb in the backligher. This applies to lcd and ordinary clocks. Led clocks are self illuminating and are often too bright for night use so there is usually facility to reduce the brightness of the display either when the car lights are switched on or when it grows dark via a photo transistor. Before junking the clock it is worth checking the ground and supply voltage...
Mar 08, 2018 | Kia Cars & Trucks
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Display light not working. can't see time at night
From the manual:
This alarm clock radio features an adjustable display backlight, with dim, medium, and bright settings. To select a backlight setting, press the Snooze/Dimmer Bar until the desired brightness is reached.
Dec 01, 2013 | Timex T309TT Clock Radio
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
My Timex t600 clock radio too dim. Love it, but I'd like to see it at night... Brightness control is at maximum...
Hello
The backlight LED of your Timex clock has got weak. It should be replaced. But it is really a skilled work as, you have to disassemble the display unit. If you are aware in electronics and have skill to do this work, you can do it by yourself. Otherwise, it will be best to get it replaced by any experienced service technician. OK.
Nov 20, 2011 | Timex T433 Clock Radio
How do you increase the volume of the backlit light?
Hello
The backlight can be adjusted as follows:
select a backlight setting, press the 3 Snooze/Dimmer Bar until the desired brightness is reached.
Please note that the backlight will not work while the clock is operating on battery power.
OK
Apr 07, 2011 | Timex T311T Clock Radio
Lcd display very dim
My clock display is extremely bright, is there a way to dim it? thanks Natalie natalie1959@gmail.com
Jun 18, 2009 | Bose Wave Radio
Want to change LCD brightness on Clock Radio
you could try to internally change the brightness, but unless you know a lot about circuits, I wouldn't mess with the internal wiring.
Nov 12, 2008 | Audio Players & Recorders
Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
Sep 01, 2008 | Emerson Smartset Clock Radio
Back lighting
Funny, I've got one I've just stopped using because the backlight is too bright, even set at its lowest.
Maybe we could trade ;-)
Is your's out completely, or just very dim?
Jan 22, 2008 | Timex T150 Clock Radio
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
169 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
