Question about Epson Perfection V700 PHOTO Flatbed Scanner
Installation. Downloaded Windows 7 compatible drivers form Epson and then connected scanner. When powered up green light turns red an loud knocking sound emanates from scanner. Computer says scanner not connected. Tried different USB cable no joy.
    Champion:
  • 331 Answers
I would check to make sure the two shipping locks are unlocked. You can find them according to the photo I have attached. This should help out.
Posted on Nov 06, 2010
Epson Perfection 2450 Photo scanner won't run on Win 7 Ultimate.
is windows 7 32 bit version or 64 bit version . Suggest downloading drivers that match the windows 7 operating system and installing them.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14558&infoType=Downloads
Mar 22, 2015 | Epson Perfection 2450 Photo Flatbed...
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
Driver for printer not compatible with win 7
The driver is classed as inbox. An inbox driver is already installed and should install automatically when the printer is connected and powered on. This if the printer driver. You will also need the scanner driver which epson say the Vista version is compatible and can be downloaded from their website.
Feb 08, 2010 | Epson Stylus RX425 Multifunction...
Can someone advise if the Epson GT-7000 scanner which I had working in XP can be made to work in Windows 7 or is it time to throw out my faithful machine? Rodney.
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
Sep 28, 2009 | Epson GT 7000 Flatbed Scanner
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Help
DOWNLOAD
Please follow the steps below to download the necessary drivers:
1. Go to the website http://support.epson.com
2. Under the ALL-IN-ONES heading select FLATBED and then your printer model.
3. Under the Drivers & Downloads section select WINDOWS. Download the most current version of the Printer Driver and Scanner TWAIN Drivers to your DESKTOP for your Windows operating system. You can also download the Status Monitor, if listed.
DOWNLOADED DRIVER INSTALLATION.
Scanner Installation
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off.
2) Locate and double click on the downloaded Twain driver installation file.
3) Click on OK at the first WinZip screen.
4) Click on UNZIP at the second WinZip screen.
5) Click on OK when WinZip is finished extracting files.
6) Follow the prompts to complete the installation.
Printer Installation
1) Locate and double click on the downloaded Printer Driver installation file on your DESKTOP.
2) Click on OK at the first WinZip screen.
3) Click on UNZIP at the second WinZip screen.
4) Click on OK when WinZip is finished extracting files.
5) At the PRINTER UTILITY SETUP screen, click on OK.
6) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer.
7) The computer will install the new hardware.
8) Click on OK when the driver installation is completed.
Status Monitor 3 Installation (optional)
1) DOUBLE-CLICK on the downloaded file.
2) Make sure the STATUS MONITOR is highlighted and then click on OK. The installer will now copy the necessary files to your computer.
3) When finished click OK and restart your computer.
Aug 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson CX3200 software
The links on Epson's page conatntly expire. Here are directions for you.
DOWNLOAD
Aug 11, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Lost my installation disk
Aug 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Perfection V700 PHOTO Flatbed Scanner Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
