Question about York Barbell Home Use Fold-Up Treadmill
Where is the elevation fuse on a Pacemaster Gold Elite treadmill?
  • prhynes59 Nov 06, 2010
    PaceMaster Gold Elite has three fuses....the two on that board are not the elevation fuses..I purchased all three fuses for it which are specifically labeled for their use...the two on the board I replaced anyway....but the fuse labed "Elevation Fuse" I can not find. I even took off the back cover to the operator control area above and can't find it on that board.
  • prhynes59 Nov 16, 2010
    Yes - thanks so much!!!
    President:
  • 1,796 Answers
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
  • Rene J Solis Nov 09, 2010
    The 2 1 /2 amp ELEVATION FUSE is located under the plug where the elevation motor plugs into on the blue circuit board.
    President:
  • 1,216 Answers
Please consult this manual
Pacemaster pro elite INCLINE MOTOR DOES NOT WORK
If you wish to get some details about treadmill repair and service ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Exercise & Fitness
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Treadmill belt will not move
This can be caused by a few things...call for service 877-805-1030
Jan 03, 2014 | PaceMaster Gold Elite Treadmill Deck
Pacemaster Pro II goes up but not down
Please RUN the software calibration for easy diagnostic, Read you owner manual and follow the steps and fix it. Or download from www.fitness.manualsonline.com
God bless you
Nov 18, 2013 | Exercise & Fitness
Pacemaster gold elite giving error code 133. Checked all connections so far and continuity through wire connecting top and bottom boards. No luck
please reset the treadmill, follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 22, 2013 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
York Barbell  Home Use Fold-Up Treadmill Logo
716 people viewed this question
Top York Exercise & Fitness Experts
mikenearman
sexykeks
sexykeks
Level 1 Expert
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
