Question about Epson Perfection V700 PHOTO Flatbed Scanner
On light turns green to red when powered on and a loud knocking sound comes from scanner. Computer says scanner not connected.
  • grthumbpete Nov 06, 2010
    Thank you, Sir.
    Champion:
  • 331 Answers
Based upon this description. There are a series of "locking" mechanisms on this scanner. They are used to prevent damage during shipping. If this scanner happens to be new and never used; I would check the following:
The first lock is on the back "left" if you look at it from the front. Then, open the cover up; and you will see the other one, just like the picture.
Thank you for accepting my answer .
Posted on Nov 06, 2010
What would a knocking machine gun sound be under hood. I just started it and somewhere under the hood is a LOUD Knocking like a Machine Gun sound.
Is it metalling sound ? if that's the case then don't drive it .. you might be having issues with connecting rod or the bearings in the both cases engine will seize. Consult a auto technician, but you wont have engine light on due to this.
If it is knocking due to misfire (which is mostly the case as the engine light is also on) .... than find which cylinder have the issue then clean or replace the spark plug. If you can get a scanner to read the car computer it will solve the issue in a blink. Otherwise start the engine ... open the hood .pull out spark plug connector one by one and notice the change in sound... the one that is bad will have no effect on the sound.
Sep 06, 2015 | 2004 Dodge Durango
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
Dec 24, 2009 | Epson Perfection V500 Flatbed Scanner
Red flashing light on power button - scanner was recently dropped.
Check to make sure the "transportation lock" on the botom of the unit hasn't got knocked to the lock position. That would make the red light flash on that model.
Nov 26, 2009 | Epson Perfection 1670 Flatbed Scanner
Ford focus car engine light coming on knocking
Go to Orielly auto parts and rent their OBD scanner. If you takethe vehicle to them they wont charge you for the scanner. The dealer will charge you $100 or more to check it for you. Depending on how loud the knock is I would not recomend driving the vehicle until you scan it. Once you scan it write down the codes and Oriellys can translate them for you also.
Sep 27, 2009 | 2001 Ford Focus
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Jan 04, 2008 | Epson 2580 Perfection Photo Scanner
Epson Perfection V700 PHOTO Flatbed Scanner Logo
450 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
