Question about Car Audio & Video
Everything is connected but cant get subs working throu my amp , its Rampage RMP 7455
3 Suggested Answers
vetteman3002
  • 2299 Answers
SOURCE: When i connect rear speakers
Either you have the back speakers hooked up to the sub woofer output channel on the head unit. Or your amp has a built in crossover. Not letting the higher frequencies get to the speakers.
Posted on Nov 05, 2010
  • 1139 Answers
Ok I am trying to understand what you are saying but it is a little difficult without seeing it :)
The fact that you have one amp to power 4 speakers and a sub is not ideal, you should have a seperate amp for the sub and then the 4 channel amp for the 4 speakers. They way they are connected is also very important. From what you are saying you are splitting the RCA cable so that you can connect it to the other 4 inputs, this seems a little strange. The RCA inputs (which should be just one red one white connector on the amp) are for low signal inputs and have a great amount of amplification. The other 4 inputs you are talking about should be high level inputs, for example a direct connection from the head unit speaker wire, NOT RCA. These high inputs are not amplified as much as the low. I am guessing that because you have split the RCA cable and put a low signal input into the high signal input, the signal is being amplified all wrong.
Can you confirm exactly what sort of input connectors there are on the amp, usually it is 1 RCA, 4 hi level inputs, power, ground, remote and then the outputs. Let me know and I will try and help you out some more.
Posted on Nov 07, 2010
Subs and amp sat in my garage for a year. I just
check your subs by connecting them straight from the stereo. If they work then there is an issue with the signal comming from the stereo through the rca cables to your amp, check those. Try another amp if you can with those rca's or test the amp with a friends car, either way try to rule out everything until it points to the problem.
Apr 17, 2010 | PPI PCX-2200 Car Audio Amplifier
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
I just installed a kenwood dnx7140. Everything is
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
Mar 08, 2010 | Kenwood DNX7140 Car GPS Receiver
I Have a Gem Sound EVA3955 amp an TR-150 subs sub stop wroking
Yes and Yes. If bypassing that noise filter, has no effect your subs could have blown.
Jan 05, 2010 | Car Audio & Video
Noise through car speakers when connected to amp
If the subs are making a humming or RPM sound check your ground on the amp , make sure its a good ground. Always run your power wire from battery by itself down one side of vehicle. Groun should be no longer than 2 feet. If that dont help you can buy a noise supresor that goes inbetween your head unit and amp through RCA's with a ground on it . Hope this helps.
Jul 25, 2009 | Alpine MRD-M1000 Car Audio Amplifier
No sound from the subs
If everything is connected correctly and the light on the amp is lite check the settings for the amp or sub in your head-unit. Consult the units manual. If you still have a problem give us more information I'm sure we can figure it out.
May 12, 2009 | Car Audio & Video
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Rampage amplifier
The amp is supposed to turn on and off with the head unit. The remote wire on the amp should be connected t othe amp control/power antenna wire of the head unit.
The pop should go away when the remote is being switched on with the head unit.
If the amp is staying on with the key removed, it will drain your battery. You need to re-wire it so you don't get stranded.
Nov 29, 2007 | Audiovox Rampage 1200 Watt Amplifier Car...
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
