Question about NetGear WNR2000 Wireless Router
I have a net gear wnr2000v2 and im having problems with the router. I woke up one morning to turn on my computer and the internet is stuck on local only. I checked the router and the 2nd light is plain orange (the one with the i symbol with a half circle under it). I turned off the router and my computer is connected to the internet due to a usb cable also being connected via the modem into the computer. The problem seems to be the router when turned on it would straight lose connection and go local with no internet connection whatsoever. I need some help.
  • 13 Answers
SOURCE: Bright house modem and desktop
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Posted on Jan 19, 2009
redhaze89
  • 854 Answers
SOURCE: WNR2000 wont connect to internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Cascading Routers (Both NETGEAR)
a. Connect one of the LAN ports of the second NETGEAR router to one of the LAN ports of the main NETGEAR router.
Note: Please make sure to configure the main router first to your Internet Service Provider using the NETGEAR Setup CD.
b. Please turn off the main router first. Then, connect a computer wired to the Ethernet port of the secondary router.
c. Reset the secondary router by pressing down the reset button for 30 seconds at the back panel. You may also refer to the diagram at the bottom of the unit on how to locate the restore factory defaults or reset button.
d. On your computer, please launch the browser and type in routerlogin.com on the address bar. If it does not work, type in routerlogin.net or 192.168.1.1.
e. If the NETGEAR Wizard popup, click on the link for advanced user.
f. If it asks for a login, enter admin for the Username and password for the Password. In case you changed your password, you'll need to enter the same password that you used before. Then, click on OK.
g. Click on LAN IP Setup on the blue portion and change the IP address under LAN TCP/IP Setup to 192.168.1.201. Then, uncheck the option Use Router as DHCP server and click on Apply.
h. Please power cycle the devices by turning off the main and secondary router. Wait for 30 seconds before turning on the routers.
i. Please try to go online.
To access the setup page of the main router, please use 192.168.1.1 and use 192.168.1.201 for the second router.
Posted on Sep 15, 2009
Geekman
  • 32281 Answers
SOURCE: PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii
.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Posted on Dec 20, 2009
  • 5 Answers
SOURCE: Cannot connect to the internet using NetGear
I understand that you are not able to go online through your NETGEAR router (WGR614v8). I apologize for the inconvenience you have experienced. Since we are doing this online, it may require a few email exchanges before we can resolve the issue. Please be assured that I will do my best effort to help resolve your case in the least amount of time.
Regarding your concern, I would recommend you to please reset and reconfigure your router (MODEL NUMBER). It is in this context, please follow the procedure stated below to configure the router:
(I) RESET THE ROUTER:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
(II) CONFIGURE THE ROUTER:
1. Connect an Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available (LAN) ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights to come on, then power on the router.
5. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
6. Access the router settings, by typing 'www.routerlogin.net', 'www.routerlogin.com' or 'http://192.168.0.1' in the address bar.
7. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
8. Click on 'Setup Wizard' (at the top of the list) from the left menu.
9. Select yes and click on next.
10. In case you get the message: 'You already have a valid Internet connection, do you still want to continue', click on 'YES'.
11. It should give you a 'Dynamic IP Detected'. Once you get 'Dynamic IP' click on Next.
12. On the next page, click on 'Apply'.
13. Once it has updated the settings click on 'Router Status' and check if there is any IP address under the Internet port.
14. If there is no IP address then please go back to 'Basic settings' from the left menu
15. Please select 'Use Computers MAC Address' from 'Router MAC Address' section and then click on 'Apply'.
16. Check for IP address again on the 'Router Status'. Once you get an IP address, please open up another browser window and try to access the Internet.
Check if you can go online on the computer hard wired to the router. Once you are able to go online. Please follow the instructions provided below to configure the wireless connection:
(III). LOGIN TO THE ROUTER:
1. On any wired computer (the computer should be connected to the router using an Ethernet cable), please open Internet Browser, like Internet Explorer, Mozilla Firefox, or Safari
2. Type in the address bar 'www.routerlogin.net', 'www.routerlogin.com' or 'http://192.168.1.1'.
3. When prompted for Username and Password, key in Username as 'admin' and Password as 'password'. Please note that, both Username and Password are case sensitive.
(IV). CONFIGURE THE WIRELESS SETTINGS OF THE ROUTER:
1. Click on ‘Wireless Settings’ under ‘Setup’ on the left hand column of the screen.
2. Under Network Name (SSID), type in any name.
3. Please select your region.
4. Please select the channel as '09' or '03'.
5. Under ‘Mode’, select the option as 'Auto 108 Mbps'.
6. Under security options, select WPA-PSK (TKIP).
7. Key in any alphanumeric passphrase that you would like to keep as password for wireless network and then click on ‘Apply’ (please note that the passphrase is case sensitive).
8. Click on Wireless Settings under Advanced on the left hand column of the screen.
9. You find two check boxes on the top, namely, “Enable Wireless router Radio” and “Enable SSID Broadcast”. Both of them should be checked and then click on ‘Apply’.
10. Click on ‘Setup Access List’. The check box that says ‘Turn Access Control On’ should be unchecked and then click on ‘Apply’.
(V). CONNECT THE WIRELESS COMPUTER (WINDOWS XP):
1. Click on 'Start' and then 'Run'.
2. Type in ‘ncpa.cpl’ and the click on ‘OK’.
3. Right-click on ‘Wireless Network Connection’ and click on ‘Properties'.
4. On top of the pop-up window, you should see a TAB named ‘Wireless Networks’. In case you do not see the same, please enable your Wireless Zero Configuration using Step (VI) given below.
5. Under wireless networks, you see a check box that says – ‘Use Windows To Configure My Wireless Network Settings’. This check box should be checked. On the bottom of the window, delete all wireless network names under 'PREFERRED NETWORKS' and then click on ‘OK’.
6. Right-click on Wireless Network Connection and click on ‘View Wireless Networks’.
7. Select your wireless network, and then click on ‘Connect’.
8. Key in your ‘passphrase’ in the pop-up box, reconfirm it and then click on ‘Connect’.
9. You should be connected to wireless network now.
(VI) ENABLE WIRELESS ZERO CONFIGURATION:
2. Type in ‘services.msc’ and then click on ‘OK.
3. You get a window with all services present on the computer. Among the last five options, please find “Wireless Zero Configuration”.
4. Right-Click on the same and click on ‘Properties’.
5. In the middle of the pop-up window, select Start Up Type as ‘Automatic’ and then click on ‘Apply’.
6. Please click on ‘Start’ under Service Status and then click on ‘OK’.
Note:- If you have a wireless laptop and if you are unable to detect any of the wireless networks in the vicinity, please double-check that the wireless switch on the laptop is turned on. Wireless switch on the laptop may be a physical switch by the sides or may be a combination of keys from the keyboard. Please look for laptop manual or contact manufacturer of the laptop in case of any confusion regarding this.
I hope this answers your query. If you need any further help, please email us back so that we can continue to work on a solution.
Posted on Feb 15, 2010
Testimonial: "Back Online! Thank you very much for taking the time to gather the info I needed to restore internet connection through my NetGear router."
  • 5 Answers
SOURCE: wndr 3300 net gear router wont work with hn 9000 hughes net modem
just buy a switch for hn9000.hughesnet and connected to ps3 .
How can I share my desktops Internet connection using a dlink router and sharing to a hp desktop with vista using a net gear router for a access point?
ask MS. it is there OS after all.
like 1milllion answers on that topic. there.
no dlink router told, it has model number, some even block sub net data in its fire wall , they are not all the same.
why not first lead off what job, give an example of just one thing shared,
1: a folder. (which one)? file sharing only?
2: printer.
3: other devices.
Vista is now obsolete so do expect head scratching on VISTA.
many just want to forget it.
The sharing methods are different on each newer windows. and more complex.
no local lan map shown by you.
ISP__cable>>>modem , Dlink-wired >>>>Netgear wifi.
like that? your topo>
if there is no firewall blocking in both routers (you must look)
then this is only VISTA question, ask MS this.
now the MS link
im not retyping all that here, ever.
https://answers.microsoft.com/en-us/windows/forum/windows_vista-networking/network-file-sharing-in-vista/3b503eb8-761c-45ff-9bb2-97009a8aa9e4
Feb 27, 2018 | HP Computers & Internet
WNR2000v2 NetGear wireless router not sending signal to Playstation 3, desktop connected to router working fine with internet. Please help
What's the distance b/w the router and the PS3?
Might have to change the wireless channel of the router to make it work.
Feb 27, 2011 | NetGear WGR614 Wireless Router
After following NETGEAR instruction to "Log in to the router using a Web browser. The URL is http://192.168.1.1 ( if you did not change the router?s IP address )." The page came up as...
Use an Ethernet cable to connect from your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ...... 192.168.123.456
(Your values probably will _not_ end with '123.456'.)
Start Internet Explorer
Type http://192.168.123.456
You should see the router's "login" page.
Jan 18, 2011 | NetGear WGR614 Wireless Router
I can not get connected. Woke up this morning and no internet conection, local only and the conection is refered to as Network.
Hello, the local only means you have connection to the router but the router does not have connection to either the modem. Did you try resetting the modem?
Turn off both devices (router and modem) turn the router on first. Then turn the modem. Wait a minute or so and the router should get the IP from the modem and it should work.
If you still have no luck, it means there's something wrong with either the modem or the actual connection from the ISP.
I hope this helps.
May 03, 2010 | Buffalo Technology WHR-G54S Wireless...
Router Suddenly stopped working...?
try power cycling your network (turn off all of the hardware)
First turn off the computer,
second, the router;
lastly the router (wgr614).
Now, turn the hardware in this order:
  1. Turn on Modem. Wait 2 minutes.
  2. Turn on Router (wgr614). wait 1 minute.
  3. Now turn on the Computer(s).
this should refresh your internet connection. If not, check your routers settings for any wrong info.
to access your router's homepage, type this (http://www.routerlogin.net) into Internet Explorer.
Aug 11, 2008 | NetGear WGR614 Wireless Router
Worked Fine and then my computer did not recive a wireless connection, and nao cant play my 360 :[
make sure the wireless part of the router is working fine by trying a computer to connect wirelessly to the router. if it connected fine then it is a matter of matching the wireless settings of the router and the xbox in order for them to synchronize properly.
Jul 02, 2008 | NetGear RangeMax WPN824 Router
Cannot connect to router wirelessly.
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
May 09, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Netgear614 to compac pc laptop
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G 2.4Ghz Broadband Router Problem
This is a common problem with linkys wireless g routers, as you say that you modem works fine with usb..no problem with your isp, so go head and first upgrade the routers latest firmware..reset and reconfig your roter your issue will get fixed..try it out.
Feb 28, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to access homeportal, but internet is ok?! (2wire 1800hw)
I had the same problem. I reset the home portal to factory setting and uninstalled the 2wire software from my main computer. I then reinstalled the system using installation cd that came with 2wire.
Jan 21, 2008 | 2wire HomePortal® 1800HW Router...
NetGear WNR2000 Wireless Router Logo
1,089 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
