Question about GE Refrigerators
The auger teeth that move the ice spring in the ice tray, is just spinning...do you know of a way to make it stop spinning freely
  • 3,083 Answers
A sensor or the timer circuit is faulty. Here is a video that discusses how GE icemaker's work, and should help:
http://www.geappliances.com/videos-media/?vuuid=hcs72kzj&categoryid=13814
On the same page is a video about how to turn the icemaker off.
They sell icemaker kits. Go to the following site and enter your model number, and you will see diagrams and parts lists that will help:
http://www.appliancepartspros.com/
Good luck, and hope this helps.
Posted on Nov 06, 2010
When crushed ice is selected it will continue and not stop
auger stuck remove bin check for ice build up behind bin or in bin clear make sure lever moves freely on bin& auger relay at rear if its a ling bin unit .
Mar 16, 2015 | Frigidaire Refrigerators
Why does my ice auger want to keep spinning and wont stop when you pull the cord it turns the auger
Pulling the cord will only start the engine. Your problem is with the centrifugal clutch. Check the clutch for broken springs. GOOD LUCK FRIEND.
Mar 02, 2015 | Jiffy Model 30 10" Ice Auger
The dispenser auger turns but is not dispensing any ice. The auger turns freely and sends ice toward the front of the bin but nothing comes out. What can be done to fix it? Does the blade toward the front...
You have a cube of ice jammed between the rings of the auger...this stops anymore ice from moving out of the auger...
remove ALL of the ice from the tray and the auger and then let it refill... then it will work again...
heatman101
Aug 05, 2010 | Frigidaire FRS26ZSG
Ice maker not working has frozen ice inside tray and had cubes on top it's just no longer moving
remove tray, ice may be frozen around auger or gear that spins auger, dump all ice and start over making ice. also, wile tray is out hi dispense switch and see if grer spiindle rotates, if not ur motor has gone bad
May 22, 2010 | Kenmore 53603 / 53606 Stainless Steel Side...
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispencer not dispensing ice
Ouch, if your auger won't turn, pull out the ice tray unit. At the back you will see the gear for the auger unit. Try and move it, both clockwise and counterclockwise. If it won't turn - you have a motor problem and needs replacement. If it turns too freely, then you have a weak motor and it will not push the ice.
Aug 21, 2009 | Frigidaire FRS26R4A Side by Side...
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Drive Mechanism Doesn't Turn
pull the ice tray out and have someone push the ice botton,look to see if the auger arm in back is moving and the ice tray auger is moving ,let me know what you find-mike
Oct 09, 2008 | GE Monogram ZISS420DRSS Stainless Steel
Ice dispenser not working
Pull out auger & try With Out auger in place with door open and see if auger motor will spin with out auger and tray IN.. you with have to push door switch in to get auger to work .. with door open
Sep 12, 2007 | KitchenAid Architect ® Series II KSRX25FT
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
