Question about Garmin nuvi 755T Car GPS Receiver
Car charger not charging internal battery ..gtm 20 cord ...nuvi 755
  • Garmin Master
  • 587 Answers
There is a fuse in the car charger adapter silver tip.... Unscrew it CAEFULLY its spring loaded and check fuse
Posted on Nov 06, 2010
    Problem Solver:
Found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered ont ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
Posted on Jan 10, 2012
Will a garmin gtm 20 charger work with a garmin nuvi 660 gps
Yes! The GTM-20 is a charger with a built-in traffic receiver. The charger plugs into the cradle for the Nuvi 660 and then the Nuvi 660 snaps into the cradle.
However to receive traffic with the GTM-20, you will need to purchase a subscription, either yearly or lifetime. The traffic receiver receives traffic information from FM radio broadcast stations, which broadcast traffic data.
Feb 23, 2014 | Garmin GPS
Garmin nuvi 760 charging problem
The wire may be defective, especially where it plugs into the connectors.
Nov 25, 2013 | Garmin Nuvi 760 Car GPS Receiver
Garmin GTM 25 charger cord has broken wire inside.
Most likely that is the FM antenna lead that goes to the traffic receiver. It should only be connected on the end that goes to the receiver.
You say the GTM-25 is not charging. Is the fuse blown? The charger takes +12VDC from the lighter socket and supplies +5VDC to the GPS.
Dec 15, 2011 | Garmin GPS
I have a Garmin Nuvi 755T. I noticed that the unit was not charging via the car charger. I checked the charger and noticed that the green light was on. I also pulled the fuse and checked it and it is...
found female jack on the 755 mount where the car charger pluges into the GPS was not securely soldered onto ckt bd so after multiple times pulg in or unpluging the unit or just stressing the connection the fine wire conncetions (about 12) tend to break forcing the unit to operate on battery mode untill battery is discharged. you an purchase a replacement GPCCradle Holder compatible with Garmin Nuvi on Amazon GPS Cradle Holder Compatible with Garmin Nuvi for about $20
Aug 26, 2011 | Garmin nuvi 755T Car GPS Receiver
My nuvi 660 seems to have "lost" the traffic portion . When I touch tools and go to look for traffic - or "settings" there is no settings . Could it be the GTM-20 FM transmitter is bad?...
If the GTM-20 Traffic Receiver is functioning, you should see a blue diamond on the main screen and you should be able to find a traffic icon in the menu.
If the diamond is grayed out, then the traffic receiver hasnt locked yet. If the traffic symbol is completely missing, then yes it could be a problem with the traffic receiver or the cradle or plug that plugs into the cradle.
The Nuvi 6xx receives traffic information from the GTM-20 receiver through the plug that plugs into the cradle.
- Jim
SHARCNET-USA
Apr 20, 2011 | Garmin Nuvi 660 GPS Receiver
My GTM 20 tip got unscrewed and the parts fell out. I put the parts together and then found out that both the car socket fuse and the GTM 20 fuse were busted. I replaced both fuses. The car socket works...
The GTM 20 can be repaired. It's likely that either you're not using the correct fuse or there's a short circuit. The short circuit would be caused by the metal tip, spring or fuse touching the outer part of the plug. There's a repair kit available from http://www.gpscity.com/garmin-replacement-parts-for-gtm2x.html
Jan 26, 2011 | Garmin GTM 20 Lifetime Traffic Receiver...
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi / gtm 20 charger not working. I think it's a blown fuse. How to replace fuse?
If yours has a plastic tip at the silver metal contact, just unscrew the plastic part between the silver ring and the silver tip. Counter clockwise! Fuse should fall out but take cautions not to lose the silver tip part. I you do it can be found at www.gpsnstuff.com
Jun 07, 2009 | Garmin GTM 12 FM TMC Traffic Receiver...
Garmin nuvi 755T Car GPS Receiver Logo
731 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
