Question about Garden
I have to replace the gearbox on my Stiga Garden Compact rideon lawn mower. What do I need to do
3 Suggested Answers
  • 246 Answers
SOURCE: ther is a container on my stiga lawn mower that
Hello chipper648:
Most of these use either 80W90 Gear Oil or SAE 50 Engine Oil for the Transmission Gear Boxes.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 38 Answers
SOURCE: disengaging blades when mowing completed
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Posted on Jul 04, 2010
Cutting deck drive belt replacement on Stiga Park 520 ride on mower
Request instructions directly from Stiga Park.
May 20, 2018 | Garden
Rideon was under flood idrain engine oil do i have drain gaer and biff oil as well. and what oil do i replace gear oil with.
Yes, you do have to drain the gearbox and diff as well, because the oil in them will also have water in it. For the gearbox, use SAE 90, Gear oil. The diff will use the same oil. Don't forget to clean or replace the spark plug, and clean the Carby.
May 02, 2015 | Mtd Yard Machines 38-Inch 12.5 HP...
My tractor will not start, battery is good; I think I need a solenoid or starter for Model # YTH180 HUSQVARNA Lawn, Tractor
Hi there I had the same problem with my rideon mower I thought it was the solenoid as battery was new but I found that the 1 of the leads that go to the battery had worn onto the chasey making it not to start put some electrical tape if worn or replace the lead.
Oct 29, 2014 | Garden
I need a stiga belt configuration
Matty, which Stiga mower have you got? also is it hydraulic or manual transmission?
Apr 20, 2014 | Garden
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
When i squeeze my auger control, my snow thrower makes loud noise and kills my engine. what kind of problems do i have?
Hi
First check the belts that they didn't run off the pulleys and get jamed. Check the idler/tightner pulley see if it spins freely. Check that nothing is jammed in auger. Try to turn auger pulley by hand if it does not turn or is noisey you have a problem in the gearbox.
Sam
Jan 07, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Steering gearbox
PartdsTreeRepairClinic will help
Feb 10, 2009 | Craftsman Garden
Garden Logo
270 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
