Question about Candy Washing Machines
GOW264D Error Code 11 - Candy Washing Machines
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
P0300 random/multiple cylinder misfire detected
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 23, 2012 | 1997 Chevrolet Astro
Code P0171
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 21, 2012 | 2004 Lincoln Navigator
What is code p1330
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Feb 15, 2012 | 2001 Volvo S80
OBD II code PO100
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 04, 2012 | 1997 Nissan Pickup
Ligth
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
Feb 01, 2012 | 2001 Chevrolet Tracker
Obd2 code p0171
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0500?
This will help.
Thanks.
Jan 28, 2012 | 2004 Ford Focus
Message d'erreur code 11:11
Error code indicating that Trailing cable faulty, replace it. But technical skills required to replace this spare..
Dec 14, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
Error code 11 - pioneer avic 1r
From Pioneer;
"Error code 11 is more specific, however, indicating that the player’s read laser cannot focus properly, most likely due to a fault with the disc."
Try a different CD, or you may have to have the laser cleaned.
Best of Luck.
Nov 17, 2007 | Pioneer GPS AVIC-X1 car radio
Washing Machines Logo
77 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
