Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I've changed cartridges in my Kodak ESP3 printer, and no ink is showing up on the printed page. I've held down the cancel and copy keys which is supposed to clean the printhead, but it still doesn't work. I've clicked on "computer" to find/download a solution but can't find anything that talks about Kodak printers.
  • 8 Answers
You need a new printhead. Call KODAK technical support and they should send you one for free.
Posted on Nov 15, 2010
  • Anonymous Nov 15, 2010
    you need a new printhead. Call KODAK techinical support and they'sll send you one for free.
Esp 3 ink used up fast
try changing your print settings to draft or a lower quality setting the higher the setting the more ink you will use.
Feb 21, 2012 | Kodak Office Equipment & Supplies
I just replaced both ink cartridges in my esp3 printer. But when I print, the page comes out blank
You need a new Print Head:
Clean the printhead, then print a test page.
  1. On the control panel, press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes. The On/Off light continues to flash during the cleaning procedure.
  2. When the On/Off light glows steady, press and hold Quantity + Cancel simultaneously until the On/Off light flashes, then wait for the test page to print.
  3. Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
    • Is the test page blank?
  4. 1-800-421-6699,Call Kodak to Report Code BP03
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer quit printing all the sudden. I changed both cartridges with new ones. Still will not print. All I get is blank documents.
Try to reseat the printhead of the printer if using the ESP3 just press at the same time copy and cancel botton to clean the pritnhead.
Now if yur done try to print again. Now if you printer when printing its act like printing but i has a blank page it means you need to replace the printhead., But when you print and then the paper just ecxit in your printer fast and smooth you need to replace the printer, Thats how you can determined which you need to replace how the paper exit to printer.
Please call kodak 1 800 421 6699 ext 05 for printhead replacement or printer replacement
Nov 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer 3 in one kodak esp3 the ink is full
upgrade the firmware of ur printer.go to kodak.com/go/printhead support.take out printhead and ink cartridges ,reseat them again.if problem still persists,call kodak @ 1800 421 6699. they will replace ur printhead free of cost
Jul 22, 2009 | Kodak 5300 All-in-One InkJet Printer
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Need to clean the heads but can't find instructions to do it.
To clean the printhead press: COPY and CANCEL at the same time.
To print a test page press: QUALTITY and CANCEL at the same time.
Go to Kodak AIO home center, click on the"?" and open the "user guide" for the complete manual. Wish they put in a printed version, put they don't. Good luck with the printer, mind has been nothing but problems. And keep trick of what you print. You will be shocked at the low output. Report it to Kodak and they might sent you new inks.
Bob D.
May 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Unable to print any thing
Remove and re-insert the cartridges.
while plugged in.
Clean nozzles, printhead, align etc...
print a test page off
Easyshare are known for eating ink up,
the ink could be all gone.
possible bad cartridge, swap out.
Regards
Richard.
Apr 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Just changed ink everything is purpleish pink esp3 kodak printe
Pink color usually indicates, color cartridge bad,
Try cleaning nozzles, head cleaner, alignment, calibration
Print off a test page,
If still bad, New cartridge, it's a bad one.
Hope this helps
Richard.
Apr 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
247 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
