Question about LG Computers & Internet
I just got an LG Flatron W2361V to hook up to my mac book pro. I have it set up with a DVI cord, and DVI to mini converter. The LG screen shows fuzzy lines going across. Is this a problem with the cords of the monitor?
SOURCE: Blinking Screen?
mine does the same thing... what is a EHT problem & how do I fix it??? thanks!
Posted on Mar 11, 2008
MerlinTech
  • 197 Answers
SOURCE: False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Posted on Jun 16, 2008
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
SOURCE: Acer AL2002W Monitor problem
a monitor that flashes on for a second and then turns off is a sign of a bad capacitor, or multiple bad capacitors.  If it is no longer under warranty you can fix it for a few dollars at the electronics store.  Unplug the monitor, pull the back off.  Look for the capacitors.  They are the round water tower looking things.  The top of the bad ones will usually be bulging, or leaking.  (the top should be flat).
Grab a soldering iron, and be sure to note the polarity (there will be a dash on one side of it, like on a battery) so that you can put the new ones in the same way.  Putting them in backwards will likely toast the monitor so get this right.  heat up the solder joints and pull the capacitors off.  Take them to an electronics store, and buy new ones. ( the capacity and voltage need to match. 12V 500uf  ... something like that, match the numbers on your capacitor(s) not the numbers I wrote here!
grab your soldering iron again, and making sure to use enough solder, but not too much put in your new capacitor(s).
I hope this is helpfull to folks.
Posted on Oct 18, 2008
SOURCE: LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Posted on Jun 03, 2009
My LG monitor w2361v menu keeps popping on and off
The real question I have is does the set have a actual button on it for Menu? If so it is one issue, if not another.
Dec 17, 2012 | LG FLATRON W2361V 23 inch LCD Monitor
How do i hook my samsung spl300 projector to my mac book pro
You can connect your Projector with the Mac Book Pro; However the problem is, mac comes with a DVI connector and your projector uses a VGA one.
You need to buy a DVI to VGA adapter from Apple if you don't have one already. You can buy it from the local apple stores or an online apple store.
There are two types of DVI-VGA adapters available (Please check the below images and see which one fits your Mac and go for it). Apple DVI to VGA Display Adapter
Apple Mini DVI to VGA Adapter Once you decided which one you need, go to an apple store or online apple shop and buy one.
Hope This helps.best regardsNextDoorNerd
Jul 30, 2010 | Samsung Mac Notebook
No image on screen
Make sure the monitor is working first. Try hook it up to a regular PC. If it works on a regular PC then make sure your Macbook's output is setup to show the video onto an external monitor.
If you can't get the monitor to show video on a regular pc then that means the monitor is bad.
Apr 22, 2010 | LG 22" FLATRON LCD Monitor
Dvd on Mac to show through projector
Yes if you are using Mac Book or Mac Book Pro then to connect a VGA projector you need MINI DVI to VGA or MINI DISPLAy to VGA or DVI to VGA.It will solve your issue
Apr 08, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
Computers & Internet Logo
187 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
