Question about Refrigerators
Top freezer model. fridge section will only cool to 48 degrees
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 06, 2010
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
The fridge is at 64 degrees and the freezer is working well. Coils are clean.
In most fridges, the cooling coils are in the freezer section. The other section is cooled by air flowing from the freezer section.There should be a valve/vent/knob that allows more or less air to flow from the freezer. Adjust this to maximum cold to see it the temp changes. Or is 64 degrees too cold for you?
May 06, 2012 | Amana ABB1927DE Bottom Freezer...
What should the temp be for freezer and refrigerator?
dont know model, do know temps. The fridges highest temp is 5deg c, preferably between 1 and 4, if freezer goes above minus(-)18deg c your are in danger zone, there should be a regulator control in the fridge, usually on left or right hand side near front(door)
Jan 25, 2012 | Kenmore Refrigerators
When set at the coldest setting the refrigerator will not go colder than 48 degrees. The freezer is holding at 10 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jan 21, 2011 | Frigidaire Refrigerators
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
Fridge is not cool enough 12 degrees C. Freezer is -3 degrees
The cooling air outlet is clogged or blocked. Cool air is not entering the fridge section as indicated by the low temperature in the freezer section. It shows that the compressor is working fine and the system is good. If your unit has a brushless DC fan motor that circulates air to the fridge section, it may not be working properly or not working at all. You have to replace it.
Nov 08, 2009 | Refrigerators
Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Jul 22, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer working Fridge NOT COOLING
fridge takes its coldnest from the freezer check if the fan is running or if the vent is close
May 12, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
