Question about Dell Inspiron 1521 Notebook
Alright, the backlight on the screen of my dell inspiron 1521 went out, so I can't see a thing. But I have it connected to another computer so I can still see it on another monitor. The problem is, I have a virus on the laptop and I want to restore the factory settings. I don't know what buttons to push, nor does the screen show when starting up on the monitor connected to it. So if you could walk me through the buttons to push for factory restoring, I would gladly appreciate it.
  • joecoolvette
    joecoolvette Nov 06, 2010
    Wow! This sounds like a bad day! Posted in a Clarification because this may be only part of a Solution. From here with info from you, I will move info to a Solution category. External monitor connected, and on. Press, and hold down on the Fn key. Now press the F8 key until External Monitor is highlighted. We have to get you a screen to look at, before we can go on.
Dipu007
  • 2110 Answers
SOURCE: How to get factory settings for my Dell Inspiron 1505
hold ctrl down and tap f11 while booting...then restore menu will come...
Posted on Dec 09, 2008
ecmorgan69
  • 279 Answers
SOURCE: I want to restore my DELL LAPTOP to the factory settings?
Okay, do as follows.
(a) Boot the computer. When you see a blue bar with www.dell.com on the screen, hit Ctrl + F11.
(b) On the next screen, click "Restore".
(c) Next, click "Confirm".
(d) Let the restore process run. It will probably take 10-ish minutes. Don't touch it while it's doing it's thing.
(e) When prompted, click "Finish" to reboot the computer.
(f) When prompted, click "Yes".
(g) When prompted, click "Next".
(h) After the computer restarts, click "OK".
Posted on Dec 29, 2008
  • 50 Answers
SOURCE: I want to restore my dell laptop to factory settings
you can try to restore your PC from start<-all programs<-accessories<-system tolls<restore
-Choose the earliest date that your want your PC to restore back to.
Hope it helped
Posted on Mar 25, 2009
  • 489 Answers
SOURCE: dell inspiron b130 laptop- internal system restore
Control + F11 when you restart.
Posted on May 28, 2009
SOURCE: i am trying to restore factory on a dell inspiron
If Administrator is the username, the password should be blank or none. (leave it blank) just click on Ok and it will go straight to the option of System Restore, Complete PC restore, Dell factory image restore. etc.. Hope this helps
Posted on Dec 09, 2009
My dell inspiron 1521 screen goes black!
Yes, most likely the inverter has failed if you can still make out the desktop but the screen is very dim. Below is the link to the service and repair manual for that model.
http://support.ap.dell.com/support/edocs/systems/ins1521/en/sm/index.htm
Jan 23, 2010 | Dell Inspiron 1521-JB Notebook
Backlight went out where do i find the backlight?
Its probably not the backlight but the LCD inverter. Just replaced one on my Acer and all is well. Bought it off of E-bay for under $10. Its a cheap and easy fix if it is actually the problem. Good luck, Todd
Dec 22, 2009 | Dell Inspiron 1521 Notebook
My dell inspiron 1100 screen goes black
Fist ot alla, try to connect the notebook to an external monitor and check if you can show image when the issue appare.
Oct 19, 2009 | Dell Inspiron 1100 Notebook
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
Inspirion laptop 1521. monitor stopped working.
The problem is the inverter, possibly a bad connection or a dry solder joint.
To check this remove the screen bezel (plastic screen surround). At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 15, 2009 | Dell Inspiron 1521 Laptop
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
yes your lucky thing is this problem is LCD CCFL lamp worn, change a new lamp should be fixed.
hwo to change CCFL lamp, step by step:
1) buy a CCFL lamp from eBay, reference:
http://shop.ebay.ca/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+Inspiron+B130+CCFL+lamp&_sacat=See-All-Categories
2) take out LCD panel
3) open the back light cover and change the CCFL lamp, reference:
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/comment-page-3/
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 28, 2009 | Dell Inspiron B130 Notebook
Usb 8.0 gb flash drive not recognized by Dell 1521 inspiron
You will need the HCSD driver/patch.
http://support.microsoft.com/kb/923293
Hope this helps
Regards
Richard.
Apr 21, 2009 | Dell Inspiron 1521 Laptop
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
Screen goes blank when on battery power
Two possibilities: The display is a power hog. It's possible that the battery is failing, and has enough power to run the PC, but not the PC AND display at the same time. You would need to replace the battery, in this case. Or, in Control Panel, in Performance and Maintenance, in Power Options, there should be settings somewhere for the display when on battery or AC power. Make sure that the one for Battery doesn';t turn the display off after 0 minutes.
Mar 03, 2009 | Dell Inspiron 1521 Laptop
Windows Error Recovery
Try booting with the disk that came with the computer and start over with a fresh install of windows
Dec 30, 2008 | Dell Inspiron 1521 Notebook
Dell Inspiron 1521 Notebook Logo
79 people viewed this question
Alun Cox
