Question about Sony Walkman Video NWZS615F MP3 Player
Sony Ipod NWJ 8142F Does not appear in the computer.I have tried the same in other pc and it is working.Would u please solve the problem
My ipod wont play through the docking system, how do i solve this? it is a sony ICF-CS10iP. i have tried unpluging it. it used to work when i had this problem before. but it hasnt worked for a couple days...
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These model Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be re-soldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Jul 07, 2011 | Sony ICF-C1IP (Black) Docking Station
A1136 80GB works when plugged into mains not on it's own even after long charge.
Try to reset it (instructions here) if not, you may need to have apple install a new battery for you
Mar 19, 2010 | Apple iPod MA446LL/A MP3 Player
My IPod reboots continuously, what's wrong?
I solved this problem on my IPod 30G unit. When I would hook it into my computer (Win XP), ITunes would crash and my IPod would just keep rebooting. Even on it's own, it would play for a few seconds and completely reboot over and over. I suspect that part of the problem is that my battery isn't holding a good charge anymore so make sure the unit is fully charged when trying to use it. This may solve the problem.
If charging it isn't the problem, hook your IPod to your data cable and plug it into your computer. Press and hold the Menu and center button for 6 seconds until the Apple logo appears. Then immediately let go and press and hold the center button and the play button for as long as it takes. You'll see a checkmark appear and your unit will go into disk mode. The 'do not disconnect' message will appear. This is good. Shut down ITunes (if it is running) and go to 'My Computer' and open that. Your IPod should show up as a drive in your listings. Right click on your IPod icon and choose to format the drive. Make sure you use a regular format and that it is being done with the FAT32 file system. It takes a while but it will eventually finish. When it is complete, unplug the IPod from your system, wait a few seconds and your IPod should default to asking you what language you want. Choose your language and hook it back up to your PC.
If things work as they should, ITunes should pop up, ask you a few questions as though it was the first time you are using it and proceed to reinstall everything as it was before.
Oct 03, 2009 | Apple iPod MA446LL/A MP3 Player
Help me please!
Reset your ipod to factory settings and try again
Sep 25, 2008 | Apple iPod nano
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
need to be recharged.
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
I Pod 80 Gb white
try resetting your ipod.. most problems are fixed by resetting it
Feb 09, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod not turning on/not recharging
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Jan 12, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Thanks
Dec 02, 2007 | Apple iPod Photo MP3 Player
80gb black ipod video
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Nov 30, 2007 | Apple iPod MA446LL/A MP3 Player
Open Questions:
Sony Walkman Video NWZS615F MP3 Player Logo
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
