Question about Fuji FinePix S7000 Digital Camera
S7000 turning off by itself
Thank you for that information. You are right, mine turns off when I somehow touch or jiggle the card door. Did you find a solution?
Thanks sooo much for your help.
  • 21 Answers
Try power reset. It should work. Good Luck
Posted on Dec 26, 2008
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Camera turns on but card not initialized, tried new card and formating but no luck.
Check if the card capacity meets the requirements from the manual. If the card capacity is to big, its very possible that you need a firmware applied to the camera in order to see your card. Also, Fuji is somehow selective when it comes to different types of card from different vendors. Try to search in the camera manual and see if you can get any info related to the type of card it uses or some suggestions from Fuji. Alternative, check on another device if your card is working, sometimes bad cards can double cross your efforts. Cheers
Dec 09, 2010 | Fuji FinePix S7000 Digital Camera
Quick battery drain with Finepix S7000. Only about 25 shots!
See if there's a firmware download on the support section of the Fuji website.
Oct 20, 2009 | Fuji FinePix S7000 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Camera turns off by itself
I have a similar problem.. I recently found out it mostly happened when I was squeezing the right side of the camera or touching the card slot cover in some way... and I discovered that the camera turns off when you open the card slot cover, so it probably has to do with contacts that touch too easily and make the camera turn off when you shake the card slot cover somehow. Now that I know the source I'll see if there's a solution. Hope this helps!
Jun 09, 2008 | Fuji FinePix S7000 Digital Camera
Zoom error
Just fixed the same problem on mine. This is what I did:
Unscrew 6 small screws around the lens casing and remove the casing (two layers ((rings)). Jiggle the inner most lens casing while you turn power on. The lens moving (i.e., auto focus) mechanism becomes unstuck. Voila.
The problem in my case was caused by the dust that accumulated inside the casing and caused the auto focus mechanism not to move freely.
Good luck.
Mar 05, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix A330
Go here for the manual in PDF format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 17, 2007 | Fuji FinePix S7000 Digital Camera
Fugi finepix s7000 auto shut off
keep camera on shooting mode.Turn dial to SET UP mode.Select POWER SAVE mode by lower navigation key.Press right navigation key to select one of the 2MIN -5MIN-OFF modes.By selecting OFF mode the camera will never be off until u turn it off.After selecting desired mode.Turn dial from set up mode to desired shooting mode.
Aug 30, 2007 | Cameras
My finepix S7000 is misbehaving
Have you/can you try another card or try the card in another Fuji camera to establish where the fault lays - Camera or Card? Also contact customer support at Fuji.
Aug 06, 2007 | Fuji FinePix S7000 Digital Camera
The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Aug 29, 2005 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
146 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
