Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
I lost my adapter to my Jump Starter Model No. BP-DLG. NEED TO KNOW WHERE I CAN GET ONE
Jumpstarts have 12-volt lead acid batteries inside.Generally a 12-13.5 volt DC charger will work. 300mA to 500mA. On the RPAT-777 and RPAT-774 (pictured) the connection is a barrel plug. 5.5 mm outside dia and 2.1 mm center hole. center positive. although a 2.5 mm center hole will work as well.
Posted on Sep 17, 2013
I have a hb-208b adapter if any one needs one
amclaims@hotmail.com
Posted on Jun 25, 2011
I have lost the power cord for my 400 Amp power on board jump starter model #VEC021STC. where can I purchase one.
THIS IS A 12 VOLT POWER ADAPTER YOU MAY USE ANY 12V ADAPTER IF IT HAS THE SAME POLARITY AND SIZE PLUG WITH AT LEAST 2 AMP CURRENT RATEING HERE IS A LINK ON AMAZON
http://www.amazon.com/HQRP-Adapter-Charger-VEC021AC-VEC021STC/dp/B009DF2RFE
Dec 09, 2014 | Vehicle Parts & Accessories
Where to find adapter
stores that sell the brand and model may have the available adapter but I doubt it if they sell them as separate parts for they all come from the manufacturer as a set. or else you may order directly from the manufacturer for the adapter.
Dec 28, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Lost the power adapter for my Power-on-Board Jump Starter 400 Amp VECO21STC unit. Where can I purchase a replacement adapter?
I just checked eBay they have a bunch if them from $ 8 and up..check it out good luck..
Jul 19, 2011 | JUMP START SYSTEM
My Duralast Gold Jump Starter does not take a charge when I plug it in to the wall socket. While the charger is connected to it, it will show the green light. But when I remove the charger, after...
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
I have a Duralast Jump Starter BP-ELG and the power cord got thown away I need to know the voltage, the current and the polartity.
Since you say, it is a 12v DC portable Jump starter, the battery inside it is also a 12V battery. You need a 12V charger (eliminator, wall adaptor or whatever you may call it) Regarding current, it could be anything above 500 mA. Better if it is a 1A or 2A or even 3 A depending on the amount you are willing to spend. Now is the most important part. The polarity. I do not know it since i do not have this equipment. Most chances are that you will find (on the RoadPro) a circle and a dot (along with a +VE and -VE marked near it) around where you plug in the adaptor. For most equipments the outer circle is the -ve and the inner dot is the +ve. (unfortunately this could be reversed in some equipments) If you can find this notation on your RoadPro you are lucky. Just go to any electronic shop and buy an adaptor (12V) that matches this circle and dot notation. The same symbol representing polarity will be marked on the adaptor also. Else, you will need the assistance of someone who can check the continuity using a multimeter. This way you can find the polarity. It is pretty easy. Hope this helps.
Jan 11, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
744 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
