Question about IBM ThinkPad R52 Notebook
Battery proplems i have ibm R-52 series laptop, i have problem in my battery... after charging my laptop to 100% its battery remains only for maximum 30 minutes..after i pluged out ac supply...i have seen other R-52 series laptops in them after charging to 100% it remains for more than 3.00 hrs..... i hv lots of problems wid minimum power of dis battery.... pls do give me some tips, how can i solve this problem...
    Champion:
  • 214 Answers
Hai,
try this
after charging the battery fully, take it out and and with a small piece of wire just rub across the +ve and -ve pins of the battery.
if it produces fairly good spark u can assume that the battery is having good health. otherwise no other choice u have to change the battery.
Also u can try this battery in another laptop and check to confirm whether it is battery trouble or anything else.
good luck
Please don't forget to rate or accept the solution
Posted on Jun 18, 2008
    Genius:
  • 2,028 Answers
I would advise getting a new battery as some batteries go bad
Posted on Jun 14, 2008
  • Ryan Rogers
    Ryan Rogers Jun 18, 2008
    How can you rate this inappropriate, you need a new battery, that's all there is to it, no miracle cure answer to this one. It's a battery they wear out!!!!!!!!!!!
My IBM R40 laptop is shutdown auto why after
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 31, 2011 | IBM ThinkPad R40 2723 Notebook
Hi, I bought Acer4741Z from India on September 2010............now, when i charge the laptop, it shows 52% charging and it wont go till 100 %. Any solution for this............pls help..............
When you first bought the laptop did you fully charge the battery for at least 20-24 hours before use? To ensure the lifespan of your laptop battery is long you will need to follow these easy steps:
1) Charge the battery at least 20 hours before use.
2) Completely drain battery power before you charge it again.
3) Try not to have the laptop battery plugged in if you re going to use AC directly from the wall socket.
You may need to purchase a new battery as this one's lifespan seems to have been reduced as it can only hold 52% charge. When you purchase another follow the above steps.
Feb 26, 2011 | Acer Computers & Internet
Acer netbook battery cannot reach 100% charge?
As rechargeable batteries age they build up what is called a 'memory' or a 'charge memory'....
Let me explain how this works...you have a new battery and you run your laptop normally until it hits 15% charge then you charge it up and use it again until about 15% then charge it again....with the charge only dropping to 15% the battery builds up a 'memory' of that over a period of time (usually over at least a year up to a couple years) and then your battery's maximum capacity is no longer 100%. Same thing happens if you dont charge it fully each time, after a while it becomes incapable of taking a full charge.
What you can do to stop that in the future....when you get a new battery every now and then run its charge down to 1% then charge it to maximum. By doing that on a regular basis you help make sure the battery remembers its full charge capacity.
Feb 19, 2011 | Acer Aspire One 521 532H 533 D260 NAV50...
T61 thinkpad does not detect battery
Normal 0 If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Oct 21, 2010 | IBM Lenovo ThinkPad T61 Notebook
Not fully charging.. always on 68% maximum full charge.
Oct 07, 2010 | Computers & Internet
What should i do for 0190 critical low battery erroe in ibm r52 laptop
Oct 06, 2010 | IBM ThinkPad R52 Notebook
My new compatible battery 02K6626 is not charging in my T20.
You can buy a completely compatible IBM ThinkPad T20 battery. Search in Google for the model of you wanted battery,then you always can find some best online laptop battery shop which have a high fame and have running for some years ,they provide both good batteries and service.
Apr 29, 2010 | IBM ThinkPad T20 2647 Notebook
My laptop computer ibm t42 does not charge the battery
Hello....those T40 series laptops which I use to support at a previous job. They would often develop these same issues. We would often keep them in stock because after a while the batteries just don't hold a charge. Its not that the laptop is not charging them. The battery simply does not hold the charge.
Gary Paul
Jan 27, 2010 | IBM ThinkPad T42 Notebook
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
IBM ThinkPad R52 Notebook Logo
69 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
