Question about Kirby G5 Bagged Upright Vacuum
The on and off switch does not work properly. it is hard to get started and will stop during operation
    Novelist:
  • 147 Answers
If there is no burning smell associated with this problem, it is quite possible that the cord is broken near the top where it is attached to the handle. It is quite common for the cord to break there.
It is also possible that it is the switch within the unit as well. Just not making a proper connection. A new switch, altho a little more costly is much harder to change than the cord.
Posted on Nov 06, 2010
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
The brush motor starts and stops during use
Is it the actual motor stopping or the belt that spins the brush that's slipping? if its belt slip, this happens, pretty common on all belt vacs, dirt and dust gets under the belt and causes it to just slip with no actual grip on the brush end. This slipping can also cause to much friction ware and actually changes the inner diameter of the belt so even cleaned it would still (maybe) slip so need a replaced belt.
But I'd take the belt off first and clean it as well as the heads it spins over then try it again. Make sure you unplug from the wall, a vac brush can and will take your fingers clean off.
Jan 01, 2010 | Hoover U8120-900 WindTunnel V2 Bagged...
The mechanical off/on in the handle is not working with the electrical on/off switch upon removal of the handle you can cut the machine off by hand but after ensuring the the handle is re-placed in the...
Hi there it's SmartAlec from NelsonVacuums.com.au here. You are spot on in your diagnosis however i have fixed heaps of these and i have found no way to tell wether its the switch or handle untill you try 1 or the other part. If you are in Australia i can get the parts for you. Hope this helps, regards Alec
Oct 26, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacing the power switch of the Eureka The Boss 4870 vacuum
its actually just held in place with two small plastic clips. so just gently start pulling the plastic housing up. it will pop off with some force. not so much that you break anything however. but there are no screws or anything. to get it back on you will need something to pry away the plastic section where the slots are for the clips. that way the clips can fit back in the slots instead of just dead ending into the handle. im sure there is a more proper way, but sometimes you have to get it done. my vacuum just stopped working one day. when I opened it up, I pushed the little connectors pretty hard back onto the switch. one of them clicked a bit. as it turns out it was just loose and therefore not making a proper electrical connection. so I pushed it snugly back together, jammed the housing back on, replaced the screws, and had it running again. just make sure to unplug it while you do this.
Sep 20, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Kirby G5 Bagged Upright Vacuum Logo
27 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
