We have zayer machine with hedenhain 151A controller. we require parameter list
Please contact to ZAYER directly. Att. Mr Angel Mujika (Technical Service Manager)
E-mail: sertec@zayer.es
He can send you the parameter list.
Posted on Nov 08, 2010
Code U1016 2000 Grand Am GT
DTC U1001-U1254 Loss of Communications
Powertrain Control Module (PCM) U1016
Vehicle not starting an running ?
Do you know anything about GM class 2 serial data network .
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring (Node Alive messages). A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that module's Node Alive message. Each module on the class 2 serial data circuit which is powered and performing functions that require detection of a communications malfunction is required to send a Node Alive message every 2 seconds. When no message is detected from a learned identification number for 10 seconds, a DTC U1016
The control module ID number list below provides a method for determining which module is not communicating. A module with a class 2 serial data circuit malfunction or which loses power during the current ignition cycle will have a Loss of Communication DTC set by other modules that depend on information from that failed module. The modules that can communicate will set a DTC indicating the module that can not communicate.
Control Module
ID Number
016
Electronic Brake Control Module (EBCM)
040
Body Control Module (BCM)
064
Sensing and Diagnostic Module (SDM)
088
Instrument Panel Cluster (IPC)
096
Do you know how to do a loaded circuit test for the power an ground circuits for that module ?
The Trainer 61 DTC Diagnostics Pt1 How The ECM Thinks
ECM Inputs and Outputs Diagnosis
Feb 28, 2017 | Pontiac Grand Am Cars & Trucks
How do I change the spindle direction on my fagor control on lathe
I take it that you have tried all the buttons on the panel. As a safety feature it a may require a combination of switches according to the fagor manual item 4 which is he set of 9 buttons bewteen the to turn switches"quote: - keyboard which allows the spindle to be controlled, it is possible to activate it in the desired direction,stop it or vary the programmed turning speed between the percentage values established by means of a spindle machine parameters MINSOVR an MAXORV with incremental steps established by means of the spindle machine parameters SOVRSTEP "
go on line and type in fagorautomation.com/downloads/manuals/en.amn_8055t_opt.pdf for a user manual download.
Dec 10, 2014 | Cars & Trucks
Code Error0x0000073
found this on net
STOP: 0x00000073 (parameter, parameter, parameter, parameter) CONFIG_LIST_FAILED
Explanation: This is a Windows 2000 Executive character-mode STOP message. It indicates the system configuration link list failed. One of the core system hives is corrupted or unreadable, or some critical Registry keys and values are not present.
User Action: If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Nov 19, 2013 | Computers & Internet
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
Sep 04, 2013 | Inverter KEB COMBIVERT F5
What is the code reading u1000 traction
Hi there:
DTC U1000 Class 2 Data Link
These DTCs set when the control module does not receive a message that it was expecting from another control module, and does not know which control module did not send that message.
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an identification number with at least one critical parameter within 5 seconds of beginning serial data communication, DTC U1000 is set. When more than one critical parameter does not have an identification number associated with it, the DTC will only be reported once.
Hope helps.
Sep 27, 2012 | 2005 Chevrolet Equinox
SIR I HAVE CX320 151A PRODUCT I LOST MY DRIVER I WANT DRIVER ON NET PLZ HELP ME WITH BEST REGARD
Canon CX320 Drivers
Please visit the above link from Canon Official Support. Select the Operating System (OS) and download the required drivers/ software.
Hope it helps! Good Luck!
CreativeTECH
Feb 04, 2011 | Office Equipment & Supplies
Hello I'm use keb f5 inverter. I have to return to the factory parameters. How I'm do it?
It is strongly suggested to contact the OEM of the machine that this inverter is being used on to obtain the actual parameter settings that are required.
There are over 1500 parameters in the inverter.
Oct 11, 2010 | Inverter KEB COMBIVERT F5
I need fanuc ot cnc parameter discription for 900 to 940
The parameters 900 to 940 are different for each type of machine. You need to specify the control
Mar 30, 2010 | Computers & Internet
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
Fax2900L machine not working according to set user parameters
You have programmed the broadcast with 1 too many numbers using the 10 key method. You wioll have to remove just 1 of the numbers in the broadcast. Not one of the quick dial numbers or one of the speed dial numbers, but one of the numbers you entered using the 10 key pad. I believe the maximum is 10, but you must leave 1 free for the memory to work.
I see that you have programmed 53 numbers for this broadcast. Why not assign speed dial numbers for those that you have used the 10 key pad for?
May 09, 2008 | Ricoh FAX2900L Plain Paper Laser
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
